Discuss
wmh1164xvs-2 micro doesn't heat up
 in
Microwave Repair
Thanks!, Ordering the Magnatron now. I'll report back once i have it installed. Thanks for ALL the help! Ads By
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » wmh1164xvs-2 micro doesn't heat up
  #21 (permalink)
Old 08-31-2012, 10:00 AM
Junior Member
bryantay is on a distinguished road
Default
Thanks!,
Ads By Google
  #22 (permalink)
Old 09-10-2012, 07:08 PM
Junior Member
Default
OK! Almost there!
I got the new Magnatron installed and the microwave is now heating properly so thanks Gene for all your help!
But....
I must have damaged or improperly re-installed one of the switches because the microwave will not shut of when i open the door. a couple of times after opening the door it did shut off after a 10 seconds or so but now it just keeps running when I open the doore
Should I replace all three switches?
How do I verify the proper wiring for the switches? I'm a bit worried that I may have inadvertently reversed the wiring on one of the switches.
Which of the 3 switches is responsible for shutting off the microwave when the door is opened?
Thanks!
  #23 (permalink)
Old 09-10-2012, 07:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Bryan,
Do not use the microwave until it's fixed.
It sounds to me like you probably miswired the door switches. Unfortunately, as you said before, you don't know how to read wiring diagrams. So, the one I posted before would not help. In such situation I need you to post description on all wires connected to the switches, using the wires color and names of the switches terminals.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #24 (permalink)
Old 09-10-2012, 07:45 PM
Junior Member
Default
Thanks Gene,
I did find this is the service manual (see images attached). Looks like i can compare the wires to these images correct?
  #25 (permalink)
Old 09-11-2012, 03:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Looks like that's right.
__________________
  #26 (permalink)
Old 09-12-2012, 07:50 PM
Junior Member
Default
Problem solved! Everything is working great now.
So I went back and checked the wiring on all three switches. Everything was wired properly. I decided to re-check the continuity on the switches and noticed one switch wasn't closing completely. Rather than showing 0 on the MM it would fluctuate from like 10-40. it was jumping around a lot. I replaced the switch and now the microwave stops properly when the door is opened.
Thanks so much Gene for all your assistance! I'm back in business now.
  #27 (permalink)
Old 09-13-2012, 03:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Bryan. I'm glad it's up and running and you can have a morning cup of hot coffee.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Micro does heat pearsonn Microwave Repair 1 04-24-2012 01:39 PM
GE micro runs but no Heat bmoore196767 Microwave Repair 1 10-06-2010 08:42 AM
GE Micro does not heat Scojo75 Microwave Repair 0 09-11-2010 01:48 PM
Micro will not heat msexton63 Microwave Repair 0 09-18-2009 02:47 PM
Micro doesn't heat water falexander Microwave Repair 0 10-21-2007 08:12 AM
