Discuss
replace bad microwave in Kenmore model 790.47853403 microwave/wall oven combo unit?
 in
Microwave Repair
Service tech advises that Microwave cannot be reparied. The oven works fine. I understand that the microwave part of this
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » replace bad microwave in Kenmore model 790.47853403 microwave/wall oven combo unit?
  #1 (permalink)
Old 08-09-2012, 02:19 PM
Junior Member
Wildt is on a distinguished road
Default replace bad microwave in Kenmore model 790.47853403 microwave/wall oven combo unit?
Brand: Kenmore   Age: 5 - 10 years
I understand that the microwave part of this unit is not sold separately.
Can the microwave be replaced on this unit?
Is its wiring integral to the whole unit, or does the microwave have a standard plug?
If I can replace the microwave, I would like to see detailed drawings so that I can determine distance to mounting screws in the feet of the microwave, and maybe find another model that can replace it
Thanks in advance
Tim
Ads By Google
  #2 (permalink)
Old 08-09-2012, 04:27 PM
Junior Member
Default Microwave is easily removed.
Microwave has bolts at four locations at feet that attaches it to frame on top of oven. Easily taken out with offset screwdriver or 1/4 drive ratchet, socket and phillips screwdriver bit. Makes it easy if you move control panel on oven out of the way
Microwave has a standard plug.
Now, all I have to do is find a microwave with dimensions that will fit.
Distance between feet on bottom of microwave are 19.5" W x 11.5" D
  #3 (permalink)
Old 02-19-2013, 06:55 AM
Junior Member
Pfennigh is on a distinguished road
Default
Were you able to find a replacement microwave that fit the mounting holes in your combo Micro/Oven? I have the same problem and am going to tackle a replacement this weekend.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Wall Oven/Microwave Combo kb5ynf Oven Repair (including Ranges and Cooktops) 1 02-15-2012 10:16 AM
Microwave/oven in wall unit drwapt Oven Repair (including Ranges and Cooktops) 0 09-02-2011 07:41 AM
GE combo microwave/oven wall unit elizmack Microwave Repair 3 05-29-2011 06:59 AM
wall mount microwave & oven combo 30 in hungtrinh Oven Repair (including Ranges and Cooktops) 2 02-16-2009 01:58 PM
Whirlpool Electric wall microwave/oven combo HiggySTL Oven Repair (including Ranges and Cooktops) 1 02-02-2009 02:33 PM
