replace bad microwave in Kenmore model 790.47853403 microwave/wall oven combo unit?
Service tech advises that Microwave cannot be reparied. The oven works fine.:mad:
I understand that the microwave part of this unit is not sold separately. Can the microwave be replaced on this unit? Is its wiring integral to the whole unit, or does the microwave have a standard plug? If I can replace the microwave, I would like to see detailed drawings so that I can determine distance to mounting screws in the feet of the microwave, and maybe find another model that can replace it Thanks in advance Tim |
Microwave is easily removed.
Microwave has bolts at four locations at feet that attaches it to frame on top of oven. Easily taken out with offset screwdriver or 1/4 drive ratchet, socket and phillips screwdriver bit. Makes it easy if you move control panel on oven out of the way
Microwave has a standard plug. Now, all I have to do is find a microwave with dimensions that will fit. Distance between feet on bottom of microwave are 19.5" W x 11.5" D :D |
Were you able to find a replacement microwave that fit the mounting holes in your combo Micro/Oven? I have the same problem and am going to tackle a replacement this weekend.
| All times are GMT -7. The time now is 01:22 AM. |
