Discuss
Sharp Microwave Unusual Problem
 in
Microwave Repair
I have a sharp r 8560 microwave 1986 vintage it has been a great microwave recently it stopped working I
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Sharp Microwave Unusual Problem
  #1 (permalink)
Old 08-09-2012, 11:44 AM
Junior Member
JEFF941 is on a distinguished road
Default Sharp Microwave Unusual Problem
Brand: -other-   Age: More than 10 years
I opened it up and found the thermal fuse on the magnatron was open ( i replaced the fuse )
the microwave turns on and the clock and display all function when the door is closed the turn table and the light go off ** but the microwave continues to run ** ( this was what evidently caused the thermal fuse to blow ? I unpluged the wire from the relay that goes to the magnatron and I can hear the relay click
( so the problenm is the relay is being energized and causing the magnatron to contiune to run ) any sugestions as to what to look for ?
Ads By Google
  #2 (permalink)
Old 08-21-2012, 11:23 AM
Junior Member
Default
Problem Solved : I Traced It To The Magnatron Relay The Points Were Fused Together ( Could Not Locate Sharp Relay Any Where ) It Is A Proprietory Part : ( Located A Heavier Duty 20 Amp Relay From Digi-key ! (( Great Folks )) 6 Bucks Drlivered To My Door In 2 Days Including Shipping : ) Had To Reconfigure The Old Relay Base To The New Relay As The Coil Pins Were Different ( No Big Deal With Some J.b.weld ) It Is Back Working 100% Hopefully For Aniother 26 Years L.o.l
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave unusual noise when heating nevjef Microwave Repair 23 01-04-2013 05:16 PM
Sharp Microwave oven Model R-330J(S) keypad problem zillah Microwave Repair 0 04-22-2012 10:04 AM
Unusual Refrigerator Problem LTColumbo Refrigerator & Freezer Repair 4 07-11-2011 04:45 AM
sharp microwave bazzel Microwave Repair 4 07-11-2009 04:02 PM
Sharp Microwave philsam Microwave Repair 0 06-08-2009 06:12 PM
