Discuss
pwer but no heat
 in
Microwave Repair
power comes on, sounds normal, maybe a little quiet. food doesn't heat up
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » pwer but no heat
  #1 (permalink)
Old 01-28-2008, 02:38 PM
obee obee is offline
Junior Member
obee is on a distinguished road
Default pwer but no heat
Model Number: JVM1410WC   Brand: GE   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-28-2008, 07:36 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Open the control panel.
Remove the wires from the high voltage transformer.
Check for 120V to the high voltage transformer when the control calls for heat.
If there is no 120V check the secondary interlock switch (the bottom switch on the door frame).
If there is nothing wrong with the switch - replace the control board.
If there is 120V then the magnetron has to be replaced.
- The part number for the interlock switch is AP2024337
- The part number for the control board is AP2026271
- The part number for the magnetron is AP2025937
Here are the break down diagrams for the GE microwave Model JVM1410WC001
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-29-2008, 12:42 AM
Junior Member
Default thanx Gene
Thank you Gene for your reply. I measured 120 Vac on the bottom of the transformer Before I order a magnatron, could you tell me how to replace it & where it is located in my unit?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
