Discuss
Whirlpool Gold Accubake
 in
Microwave Repair
gene and trent--i am having and have for sometime a similar problem--the MW acts normally but does not heat---sometimes--it will
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Whirlpool Gold Accubake
  #11 (permalink)
Old 04-06-2008, 10:23 AM
Junior Member
bemaag is on a distinguished road
Default
gene and trent--i am having and have for sometime a similar problem--the MW acts normally but does not heat---sometimes--it will kick on --you can hear trhe distinctive sound---and then will stop heating, steathily, and we discover it is not been hot. put popcorn in and sometimes it will start up heating stopping sometime during the cycle---sometimes it wint start at all. i have tried starting and stopping the MW and sometimes that works---other times does not. have had an experienced repairman try his magic and he is stumped--thermostats--twice--and other parts all to no avail---any suggestions?
  #12 (permalink)
Old 05-25-2018, 03:46 AM
Junior Member
ChdoulaDIY is on a distinguished road
Default
Quote:
Originally Posted by RegUS_PatOff View Post
it could be the MAGNETRON TOD (thermal overload device)
So I have a similar problem.
The microwave of GMC305PDB6 combo does not heat up anything anymore. It blows cold air from its top grill vents, and makes a whizzing noise when activated. But everything else works fine otherwise.
1. Is it likely the magnetron or the diode that needs to be replaced??
2. Where are these parts located in the microwave ? Do I need to pull out the microwave-oven combo from the wall to test and check these parts?
Please advise.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Gold Accubake oven error code E0 -F2- sajajea Oven Repair (including Ranges and Cooktops) 1 09-26-2009 02:45 AM
whirlpool accubake gold gas range lorettabean Oven Repair (including Ranges and Cooktops) 3 06-15-2009 07:22 PM
Whirlpool Gold Accubake temperature setting sforman1 Oven Repair (including Ranges and Cooktops) 6 05-16-2009 07:47 PM
Whirlpool Gold Accubake Microwave Roatan Microwave Repair 2 11-10-2008 05:26 AM
Whirlpool Gold Accubake door helplessMICROman300 Microwave Repair 5 09-04-2008 09:45 PM
