| » oster microwave wiring repair question |
Model Number: otm1101gbs Brand: -other- Age: 1 - 5 years
Microwave started smelling like burnt plastic/rubber then shut-off itself while heating a mug of coffee. After this, the unit would not power back on (also tested the outlet and the microwave in other wall outlets). I took the outer cover off of it and saw a wire/connection had burnt out towards the top of the unit (see 3 pictures linked below).
I'm somewhat handy with wood & construction, but know little about electronics repair. I was wondering if this is something that I could fix myself - and if I did (or tried to fix it) is it most likely worthwhile to try - as opposed to buying a new one. Also, could I buy generic replacement parts or would I have to order them from Oster. And finally, how much would/should a local repair shop charge to fix this? Any help would be greatly appreciated, Pictures: http://www.bilbyweb.com/microwave/1.jpg http://www.bilbyweb.com/microwave/2.jpg http://www.bilbyweb.com/microwave/3.jpg ----------------------- Unit Specs Oster Microwave Stainless Steel exterior model: otm1101gbs 1.1 cu ft input: 1450w output: 1000w online manual: http://dl.anyusermanual.com/pdf/man/...anual-3544.pdf Ads By Google Related Models |
| Display Modes | |
| oster microwave | pauly 2012 | Microwave Repair | 2 | 07-22-2012 11:39 AM |
| Microwave turntable repair question | Ummagumma | Microwave Repair | 1 | 03-29-2012 12:39 PM |
| Switch wiring question | rustypryor | Oven Repair (including Ranges and Cooktops) | 1 | 01-26-2012 01:16 PM |
| Oven wiring question | tommyboy84 | Oven Repair (including Ranges and Cooktops) | 3 | 09-15-2008 03:29 PM |
| Microwave/microoven repair question? | ncpitman | Microwave Repair | 0 | 12-07-2007 09:12 AM |
