Discuss
Kenmore/LG microwave intermittent use
 in
Microwave Repair
While running, the microwave died a few days ago with no power to the unit. There was no blown fuse
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Kenmore/LG microwave intermittent use
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-28-2008, 06:50 AM
healeypd healeypd is offline
Junior Member
healeypd is on a distinguished road
Default Kenmore/LG microwave intermittent use
Model Number: 80402400   Brand: Kenmore   Age: 1 - 5 years
While running, the microwave died a few days ago with no power to the unit. There was no blown fuse and I checked another outlet I knew to be working.
After reading through posts here, I took the unit down, pulled it apart and began looking for the thermal fuse with limited success. While checking the current, I lifted a plastic casing (about 3 inches long by 1/3" around) located a few inches behind the top of the control panel and power returned to the unit.
I re-installed the microwave and used it for several minutes. About 6 hours later, I noticed that the unit was dead again.
At this point I'm not sure if the fuse could be the issue if it came back on. If so, any diagrams to help locate the fuse would be greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-28-2008, 10:11 AM
RegUS_PatOff RegUS_PatOff is offline
Member
RegUS_PatOff is on a distinguished road
Default
diagrams & parts lists
http://www3.sears.com/Paul/model_sea...um=72180402400
  #3 (permalink)
Old 02-04-2008, 05:18 PM
Junior Member
Default
Thanks RegUS. It looks like the 'plastic casing' I referred to was the fuse cap. The microwave comes on every now and then and sometimes opening and closing the door firmly will restore power to the unit. Could the fuse be blown and still work at times? Does this problem sound familiar to anyone?
Thanks-
Pat
  #4 (permalink)
Old 02-04-2008, 05:59 PM
Member
Default
Quote:
no, but there could be a loose connection somewhere.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Microwave Fault Code F6 Charles Lile Microwave Repair 2 08-25-2008 04:58 PM
intermittent compressor jdea Refrigerator & Freezer Repair 3 12-12-2007 06:59 AM
Kenmore Microwave no power beakle Microwave Repair 1 12-02-2007 07:24 AM
intermittent operation buck Washer Repair 0 11-17-2007 09:44 AM
intermittent Cooling GE bobp Refrigerator & Freezer Repair 0 08-14-2007 05:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
