Appliance Repair Forum
-   Microwave Repair (http://forum.appliancepartspros.com/microwave-repair/)
-   -   Microwave Flipping Breaker (http://forum.appliancepartspros.com/microwave-repair/491601-microwave-flipping-breaker.html)
jennieleighjones 07-25-2012 01:00 PM
Eery time I open the microwave door, my breaker flips.
Simon / APP Team 07-25-2012 03:21 PM
Hi.
Check if your microwave is plugged in to GFI outlet.
Plug it in to a regular one.
Post the results.
Simon.
jennieleighjones 07-25-2012 03:44 PM
hi there. thank you for your response. but yes. its plugged into gfi ... actually a DEDICATED outlet that is gfi. been there for 6 years ... just TODAY started flipping breaker when i open door.
wondering if its the "light" flipping it when i open the door? if so, what part would i replace? the light bulb? or door assembly? etc?
Simon / APP Team 07-25-2012 04:36 PM
Hi.
Try non GFI outlet first.
Simon.
jennieleighjones 07-25-2012 05:15 PM
Hi Simon. I've moved it to a non-GFI outlet and once again - when i opened the door to the microwave - it flipped the breaker.
If I close the door, turn the breaker back on, and use the microwave ... it works fine UNTIL i open the door again. (Which is each time I want to remove or add to the dish just cooked. :) )
Simon / APP Team 07-25-2012 06:13 PM
Hi.
Remove the cover and check the performance of the door interlock and monitor switches.
Here are the breakdown diagrams and Replacement parts for General Electric JES1142SJ04 Counter top microwave | AppliancePartsPros.com
#1445,#2010.
Thank you.
Simon.
