I replaced a burned out bulb in the base plate and when I attempted to turn the lights on it shorted out and blew both bulbs. I replaced the entire base plate with a new one with new lights; however when I attempted to turn the lights on they still will not work even thoujgh everything else on the microwave works. Would a blown fuse cause this or do I have another problem?
