Discuss
advantium: turntable and light always ON - main relay
 in
Microwave Repair
I have a GE Advantium Microwave/Convection/ETC oven. The interior bulb died. We've replaced it. Now the bulb
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » advantium: turntable and light always ON - main relay
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-26-2008, 07:46 PM
dcg9381 dcg9381 is offline
Junior Member
dcg9381 is on a distinguished road
Default advantium: turntable and light always ON - main relay
Model Number: SCA1000H   Brand: GE   Age: 1 - 5 years
Now the bulb says lit and the turn table is turning all the time.
The common component is a "main relay" - either the main relay is shorted closed or the control board is telling it to stay closed.
1) How do I find the main relay?
For those in the future that want to avoid the $250 service call for replacing that internal light, here's how you do it:
GE Advantium Microwave Halogen Lightbulb Replacement (Do It Yourself): Bulb Replacement - Instructables - DIY, How To, home, tech
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-27-2008, 09:51 AM
RegUS_PatOff RegUS_PatOff is offline
Member
RegUS_PatOff is on a distinguished road
Default
http://www3.sears.com/Paul/model_sea..._num=SCA1000H*
the turntable motor doesn't seem to go through the MAIN RELAY
it goes through the FAN MOTOR RELAY on the SUB P.C.B.
  #3 (permalink)
Old 01-27-2008, 02:16 PM
Junior Member
Default
Sorry.. wrong model.. Model should be:
SCA1001KSS01
  #4 (permalink)
Old 01-27-2008, 02:55 PM
Member
Default
the parts list may be a little different, the schematic is the same:
http://www3.sears.com/Paul/document_...sc=MICROWA VE
  #5 (permalink)
Old 01-28-2008, 01:27 PM
Junior Member
Default
Hmmm... I don't know what the deal is.. The microwave had a circuit diagram in it, buried near one of the boards.
That diagram shows the main relay feeding the turn table, the interior light, and the exhaust fan.
This one does show the turntable motor and fan motor (exhaust) being connected to the Fan Motor relay...
Here's the "short" question:
If a relay on one of the boards is bad, can that relay be replaced or are most service persons going to want to replace the entire board (component)?
  #6 (permalink)
Old 01-28-2008, 02:46 PM
Member
Default
they replace the whole board.
you may be able to replace the relay if you can find a replacement (not too difficult ), and know how to solder.
  #7 (permalink)
Old 02-09-2008, 03:14 PM
shrewmm shrewmm is offline
Junior Member
shrewmm is on a distinguished road
Default How to fix main relay RY1
I had a similar problem. The light burnt out and after replacing it the light stays on with turn table and fan. The relay is RY1 which is found on the main board behind the display and buttons.
The fix. Tap on the RY1 relay with a screw driver.
  #8 (permalink)
Old 06-29-2008, 12:26 PM
jim64 jim64 is offline
Junior Member
jim64 is on a distinguished road
Default Just tap it! :-)
To: shrewmm
Fr: me
Msg: You da' man!
I followed your directions and tapped the relay and VOILA! the carousel stopped and the light turned off. It was interesting to note that I heard several relays clicking after I repowered the unit and set the time. I hadn't noticed that before when I was unplugging and replugging the microwave - and resetting the clock each time so I could use it. Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave turntable mbuckeye Microwave Repair 2 02-01-2008 04:39 AM
Advantium inside light edgineer Microwave Repair 1 01-26-2008 07:40 PM
Glass Turntable in Microwave Bob Piersall Microwave Repair 0 01-12-2008 08:25 AM
turntable not working, everything else is good mcary Microwave Repair 4 11-09-2007 06:31 PM
turntable not working, everything else is good mcary Microwave Repair 0 11-09-2007 01:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
