| » How to test Thermal Cut-Out sensors (TCO's)? |
Model Number: 363.63693301 Brand: Kenmore Age: 1 - 5 years
I have a Sears Kenmore Advantium 120 microwave/convection/speedcook oven that is completely dead. No power. With the fantastic help from this forum and this thread in particular, I found that the 12 amp fuse is blown, so I need to order one and hopefully that will fix the problem.
But since I have it out, I'd really like to check the temperature sensors (TCO's?) if possible and make sure they are also OK, since that is what most others have had issues with. I found on page 51 of the service manual found in another thread, there is a table of Thermal Cut-Out Values for each TCO; at what temp they are open and closed. But having trouble interpreting it. It says to use a Ohmmeter to check for an Open TCO. For example: Hood TCO: Open=104F Close=133F If I put an Ohmmeter across the terminals of a TCO while in my garage, what should I see that will tell me if it's good or bad? Just checking for continuity, my Magnetron TCO was the only thing that checked out, so I know that's not correct. Thanks, Tom Related Models Last edited by Gunn : 09-16-2009 at 02:16 PM. |
Ok, so I'll answer this myself. How to test for a bad TCO:
Remove the TCO in question. Jumper the wires. Plug in the microwave. If it starts working, the removed TCO is the bad one! In my microwave, testing for continuity using a TCO may not work. My magnetron TCO and cavity TCO should pass a continuity check. But the hood TCO would be open normally and would fail the check, even though it's fine. Trial and error seemed to be the way to go. FWIW, my cavity TCO was bad. |
| Display Modes | |
| Dampness sensors - which wire goes where? | BentBoyscout | Dryer Repair | 1 | 08-27-2009 04:52 PM |
| how to test Thermal limiter | pcalnc | Dryer Repair | 1 | 05-27-2009 05:42 AM |
| disable "door open" sensors | arib | Refrigerator & Freezer Repair | 2 | 11-01-2008 06:17 PM |
| 800 series kenmore with no sensors? | hardhat | Dryer Repair | 0 | 12-14-2007 08:06 PM |
| moisture sensors | autoxracer | Dryer Repair | 3 | 09-04-2007 09:04 PM |
