| » ge Microwave Control Panel Problems |
Model Number: HVM1540PNIBB Brand: GE Age: 1 - 5 years
It never fails. My microwave just turned 13 months old and now the number keys won't work on the control panel. I had to cook my oatmeal by pressing the "add 30 sec" key 4 times this morning.
Does anyone know how I can fix this problem without spending more than a new microwave would cost? Ads By Google Related Models |
Most likely the problem is a bad key panel. The model number you posted does not come up. If you need the correct part number then verify the model number and repost it. Post the color of the control panel as well.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
My receipt says the model number is HMV1540DN. It is a black over the range microwave and was purchased from Home Depot. Here is the link: GE 1.5 Cu. Ft. Over-the-Range Microwave Oven - HVM1540DNBB at The Home Depot
Thanks in advance! Last edited by superstud90 : 09-15-2009 at 06:45 PM. |
The correct model number, you posted now, helped to find the correct part number.
- The control panel assembly Part number: AP4355865 You can call the Appliance Parts Pros customer service to find the part ETA. Gene.
__________________
I have the same problem and wondered how it was resolved? My 30 second interval works but part of the keypad does not. Mine is also just out of warranty. Part no. GE - JVM1540 SN#- RR901207B. What do I need to replace? Thanks.
Quote:
__________________
Using my model GE # JVM2070SK02 Spacemaker (green panel)
Lights went out, all works, interior light, under light, but CONTROL PANEL when pushed goes black. Or it takes me to a HELP menu, does not respond to what is touched. I cut of circuit breaker, took offline unplugged 5min, nothing it pops up to set clock, but goes to help menu when I push anything. Appreciate this OUT OF WARRANTY assistance |
Sounds like the control panel has gone bad. Unfortunately this part is very expensive.
- The control panel assembly Part number: AP3883118 Here are the breakdown diagrams and Replacement parts for General Electric JVM2070SK02 Counter top microwave | AppliancePartsPros.com Gene.
__________________
My microwave control panel was screwing up for awhile, wrong numbers came up or not at all, and now nothing is working. Is this a control panel replacement or a simple fuse replacement? White GE JVM1650WB005 Thanks, Crystal |
Hi Crystal,
If "nothing" means that you can not input anything from the keypad then most likely the problem is a bad keypad. If you can input any command but the microwave does not perform then the problem could be a bad control board. - The keypad Part number: WB27X10253 - The control board Part number: WB27X10382 Here are the breakdown diagrams and 01-Microwave parts for GE JVM1650WB005 - AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Control Panel Problems for Maytag Dishwasher | tommyboy84 | Dishwasher Repair | 7 | 05-17-2013 06:56 AM |
| Whirlpool Dual Oven Control Panel Problems | fiorillo | Oven Repair (including Ranges and Cooktops) | 22 | 10-16-2010 02:53 AM |
| Control Panel problems | CharlieG | Oven Repair (including Ranges and Cooktops) | 3 | 06-08-2009 04:49 PM |
| Whirpool Duet Gas Dryer control panel problems | moeman12 | Dryer Repair | 3 | 02-28-2009 10:29 PM |
| Whirpool Duet Gas Dryer control panel problems | moeman12 | Dryer Repair | 0 | 02-24-2009 06:41 PM |
