Discuss
Microwave, tried everything - bad Magnetron?
 in
Microwave Repair
Hello, I'm having issues with a LG LMV2053 microwave. It seems to work correctly except there is no heat. This
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave, tried everything - bad Magnetron?
  #1 (permalink)
Old 07-01-2012, 06:33 PM
Junior Member
SidAPP is on a distinguished road
Default Microwave, tried everything - bad Magnetron?
Model Number: LG LMV2053   Brand: -brand-   Age: 1 - 5 years
Hello,
I'm having issues with a LG LMV2053 microwave. It seems to work correctly except there is no heat. This happened after by son left the microwave on for an hour with nothing in it thinking he set the timer. There doesn't seem to be any loud noises or buzzing but I don't hear very well. Here is what I have tried so far:
1 – Disconnected the Primary Terminals from the HV Transformer.
2 – Ran a cook cycle measuring the input voltage to HV Trans = steady 123VAC.
So LV side seems to be fine. Ran the following tests on HV comps:
Magnetron:
1 – Removed all wires to the terminals.
2 – Measured resistance (R x 1) from one term to the other = 0+ ohms.
3 – Reversed leads from above, still 0+ ohms.
4 – Measured resistance (R x 1K) from each terminal to housing = infinity.
5 – Visually inspected the unit and it looks ok. Some of the fins are discolored (brown and gold) due to heat/burning. The rest look new bright silver.
6 - Put a 10 ohm resistor on the diode cathode to ground and ran the microwave. I measured .123 VDC which I've read is very low, should be -3 to -4 VDC.
Capacitor:
1 – Measured resistance (R x 1K) between the two terminals:
Initial reading = infinity
Swapped leads = High level resistance, then faded to infinity
Swapped leads again = High level resistance, then faded to infinity
2 – Measured both leads to metal case = infinity for both.
Diode:
Removed diode from circuit and ran 123VAC through it and measured 65VAC RMS both ways. The diode appears to be working as it should.
HV Transformer:
1 – Disconnected all wires.
2 – Measured resistance (R x 1) between the three Primary Terminals = .2, 0+, .2 ohms.
3 – Measured resistance between the two orange leads (filament) = 0+ ohms.
4 – Measured resistance between each terminal and chassis = infinity.
5 – Measured resistance from yellow secondary to chassis = about 70.8 ohms.
I’m leaning toward a bad magnetron. What do you think?
I would be willing to gamble on a $50 magnetron or a $85 transformer but not both. It's not worth $135. Your thoughts or other suggestions?
Thanks again for all your help!
Ads By Google
Related Models
Amana LG1009W Dryer - Gas
Amana LG1101 Dryer - Gas
Amana LG1112 Washer - Top Loading
Whirlpool LG2001XSW0
Amana LG2112L Dryer - Gas
Amana LG2112W Dryer - Gas
Amana LG2401 Dryer - Gas
Amana LG2412 Dryer - Gas
Amana LG2501 Dryer - Gas
Amana LG2512 Dryer - Gas
Amana LG2811 Dryer - Gas
Amana LG2812 Dryer - Gas
Amana LG2902 Washer - Top Loading
Amana LG2911 Dryer - Gas
Amana LG2912 Dryer - Gas
Whirlpool LG3001XKW0
Whirlpool LG3001XMW0
Whirlpool LG3001XMW1
Whirlpool LG3001XMW2
Whirlpool LG3001XPW0
Whirlpool LG3001XSW0
Whirlpool LG3006XPW0
Amana LG3412G Dryer - Gas
Amana LG3412L Dryer - Gas
Amana LG3412W Dryer - Gas
Amana LG3512L Dryer - Gas
Amana LG3512W Dryer - Gas
Amana LG3812L Dryer - Gas
Amana LG3812W Dryer - Gas
Amana LG3912L Dryer - Gas
Amana LG3912W Dryer - Gas
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L Dryer - Gas
Amana LG4209L2 Dryer - Gas
Amana LG4209W Dryer - Gas
Amana LG4209W2 Dryer - Gas
Amana LG4219L2 Dryer - Gas
Amana LG4219W2 Dryer - Gas
Amana LG4309L Dryer - Gas
Amana LG4309W Dryer - Gas
Amana LG4319L2 Dryer - Gas
Amana LG4319W2 Dryer - Gas
Amana LG4409L Dryer - Gas
Amana LG4409W Dryer - Gas
Amana LG4429L Dryer - Gas
Amana LG4429W Dryer - Gas
Whirlpool LG4441XWW0
Whirlpool LG4441XWW1
Amana LG4509L Dryer - Gas
Amana LG4509W Dryer - Gas
Amana LG4609L Dryer - Gas
Amana LG4609W Dryer - Gas
Amana LG4809L Dryer - Gas
Amana LG4809W Dryer - Gas
Amana LG4909L Dryer - Gas
Amana LG4909W Dryer - Gas
Whirlpool LG4931XMW0
Whirlpool LG4931XSW0
Whirlpool LG4931XTF0
Whirlpool LG4931XTG0
Whirlpool LG4931XTM0
Whirlpool LG4931XTN0
Whirlpool LG4931XTN1
Whirlpool LG4931XTW0
Whirlpool LG4931XTW1
Whirlpool LG4931XTW2
Whirlpool LG4936XMW0
Whirlpool LG4936XMW1
Whirlpool LG5201XTF0
Whirlpool LG5201XTG0
Whirlpool LG5201XTM0
Whirlpool LG5201XTN0
Whirlpool LG5201XTN1
Whirlpool LG5201XTW0
Whirlpool LG5201XTW1
Whirlpool LG5321XTF0
Whirlpool LG5321XTG0
Whirlpool LG5321XTM0
Whirlpool LG5321XTN0
Whirlpool LG5321XTW0
Whirlpool LG5531XKW0
Whirlpool LG5531XKW1
Whirlpool LG5531XMG2
Whirlpool LG5531XMN2
Whirlpool LG5531XMW0
Whirlpool LG5531XMW1
Whirlpool LG5531XMW2
Whirlpool LG5531XPW0
Whirlpool LG5531XSW0
Whirlpool LG5531XSW1
Whirlpool LG5536XPW0
Whirlpool LG5551XTG0
Whirlpool LG5551XTN0
Whirlpool LG5551XTW0
Whirlpool LG5601XKW0
Whirlpool LG5601XMW0
Whirlpool LG5601XPW0
Whirlpool LG5601XSW0
Whirlpool LG5601XSW1
Whirlpool LG5606XPW0
Whirlpool LG5651XKW0
Whirlpool LG5651XKW1
Whirlpool LG5651XMW0
Whirlpool LG5651XMW1
  #2 (permalink)
Old 07-02-2012, 02:38 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The filament winding should give you some resistance reading, not just continuity. Also the filament voltage is normally 3.5-3.7 VAC.
If you will get parts from APP you can return any unused ones even if they been installed.
Here are the breakdown diagrams and Replacement parts for LG LMV2053SB Microwave Oven | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-02-2012, 10:53 PM
Junior Member
Default
Hello Simon,
It was hard to tell if the filament winding had any resistance. One of my meters read 0 ohms and the other more expensive one keep switching between 0 and .1 ohms. That's why I put 0+ ohms above.
Just to make sure I'm clear what are you calling the filament voltage - voltage across the resistor I mentioned above?
I took you up on the parts and went ahead and ordered both the magnetron and transformer hoping I will only need one or the other.
Thanks for your response,
Clarence
  #4 (permalink)
Old 07-03-2012, 11:10 AM
Expert
Default
You are welcome. Post the results.
Simon.
__________________
  #5 (permalink)
Old 11-10-2012, 08:31 AM
Junior Member
Default
I replaced the magnetron and the microwave has worked fine for several weeks. Now the microwave has a short buzzing or hum sometimes when it's first turned on to heat. It seems to work ok other than the noise. What do you suggest? What should I test or look for?
  #6 (permalink)
Old 11-12-2012, 11:37 AM
Expert
Default
Hi.
Sounds like the magnetron on it's last leg again.You should replace it under the warranty.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave magnetron installation kennow1 Microwave Repair 1 12-31-2011 10:40 AM
GE JKP85 Microwave Magnetron nowinus Microwave Repair 0 08-23-2011 12:44 PM
Ge Microwave Magnetron Fan Motor FUNGER Microwave Repair 0 06-15-2011 07:47 AM
Microwave Magnetron tonyvol Microwave Repair 0 04-28-2010 05:50 PM
Microwave Magnetron Check joecephus1963 Microwave Repair 6 09-16-2009 03:08 PM
