I am installing the unit and I looked for the "Exhaust Damper". None was with the unit. I ordered, what I thought was the damper and received the damper housing only; no damper. As this is also identified as the "Main Damper" one would think this is an important part to be installed. The installation instructions even tell you to "Clip the Damper Corners" to allow clearance in the ducting. This seems to be an important part of the installation process and I don't have the piece to install. What do I do now? Bob
