Discuss
Don Alvin
 in
Microwave Repair
Hello. I am having issues with the Micro oven door swithches. I have replaced both the right and left side
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Don Alvin
  #1 (permalink)
Old 05-16-2012, 01:51 PM
Junior Member
timbercreek@mwt.net is on a distinguished road
Default Don Alvin
Model Number: KEMC308KSS03   Brand: Kitchen Aid   Age: 1 - 5 years
Hello. I am having issues with the Micro oven door swithches. I have replaced both the right and left side swithes and the holders.
After doing so I still get the DOOR OPEN notice. I took both left and right side switches out again and looke at the wiring and on the right side PRIMARY INTERLOCK AND MONITOR SWITCHES, there is a jumper wire that goes between the two swithces that is blue. It seems to suppy power to both switches as the blue jumper is connected to the black wire on the other switch.
Now I took the right switch out and looked real close at the wires and found a wear mark in the blue power wire and a burn mark on the inner cabinet where the wire seems to have rubbed.
Can you tell me what may have shorted out when the wire shorted out on the cabinet? If it helps the light in the micro also does not work even with the new bulb.
Thank You
Don Alvin
Related Models
Whirlpool KEMC308KSS03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC308KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC308KWH0 BUILT-IN OVEN, ELECTRIC WITH MICROWAVE
Whirlpool KEMC308KWH01 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC308KWH02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC308KWH03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC308KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC377KBL0 BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMC377KBL01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBL03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBL05 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBS0 BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMC377KBS01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBS02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBT0 BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMC377KBT01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBT02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBT03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBT04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KBT05 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KSS05 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KWH0 BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMC377KWH01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC377KWH05 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER CRISPWAVE MICROWAVE
Whirlpool KEMC378HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEMC378HBL1 OVEN
Whirlpool KEMC378HBL2 OVEN
Whirlpool KEMC378HBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMC378HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEMC378HBT1 OVEN
Whirlpool KEMC378HBT2 OVEN
Whirlpool KEMC378HBT3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMC378HWH0 BUILT-IN ELECTRIC OVEN
Whirlpool KEMC378HWH1 OVEN
Whirlpool KEMC378HWH2 OVEN
Whirlpool KEMC378HWH3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMC378KBL0 OVEN WITH MICROWAVE
Whirlpool KEMC378KBL01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KBL03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KBT0 OVEN WITH MICROWAVE
Whirlpool KEMC378KBT01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KBT02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KBT03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KBT04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS0 OVEN WITH MICROWAVE
Whirlpool KEMC378KSS01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH0 OVEN WITH MICROWAVE
Whirlpool KEMC378KWH01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMI300SBL0 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300SBL1 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL0 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL1 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL2 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL3 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL4 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL5 BUILT-IN OVEN WITH MICROWAVE
KitchenAid KEMI300WBL0 ELEC. BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL1 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL2 ELEC BUILT IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL3 30" BUILT-IN COMBINATION OVEN
Whirlpool KEMI301BWH0 30" ELECTRIC BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI301GBL0 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEMI301GWH0 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEMI371BBL0 27" BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMI371BBL1 27" BUILT-IN OVEN
Whirlpool KEMI371BBL2 27" BUILT-IN OVEN
Whirlpool KEMI371BWH0 27" BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMI371BWH1 27" BUILT-IN OVEN
Whirlpool KEMI371BWH2 27" BUILT-IN OVEN
Whirlpool KEMI371GBL0 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEMI371GWH0 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEMI371SBL0 Ranges, Electric*
Whirlpool KEMI371TBL0 Ranges, Electric*
Whirlpool KEMI371TBL1 ELECTRIC RANGE
Whirlpool KEMI371TBL2 ELECTRIC RANGE
Whirlpool KEMI371TBL3 Ranges, Electric*
Whirlpool KEMI371XBL0 Ranges, Electric*
Whirlpool KEMI371XBL1 Ranges, Electric*
Whirlpool KEMI371XBL2 Ranges, Electric*
Whirlpool KEMI371YWH0 Ranges, Electric*
Whirlpool KEMS306BAL0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BAL1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BAL2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BAL3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BBL0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BBL1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BBL2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BBL3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BWH0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BWH1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BWH2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BWH3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306XAL0
Whirlpool KEMS306XAL1
Whirlpool KEMS306XAL3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XAL4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XAL5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XAL6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS306XBL0 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMS306XBL1 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMS306XBL2 ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XBL3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XBL4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XBL5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XBL6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
