replaced the door spring and inner bulb with the help of this forum, had to remove the control panel to change bulb in micro, put it back together, now not resetting timer after microwave done cooking when you open the door like before, also microwave fan continues on when you open door while cooking but turntable stops, where before fan and everything stopped before when door opened, saw someone did have a problem with ground that caused somewhat of the same problem, checked ground clip on back of control panel, seems tight, any help appreciated, thanks
