I am working on a Sharp R8350 convection microwave. The fuse blows instantly when the microwave is turned on. The fuse does not blow when using the convection side of the oven. I have replaced the diode but may have received a bad diode. I tested the new diode and it ran to infinity with no resistance at all. Tested via positive probe to anode and negative probe to cathode side.
What component(s) should I test next? I am stumped.
