| » Microwave power output low |
Model Number: Thermador smw272 Brand: Thermador Age: 5 - 10 years
I have a Thermador model smw272 with a built in microwave
It does not heat well. It is losing the ability to heat food at the same rate that is has in the past. I tested the temp rise with 32oz of water and the temp rose 12 degrees in one min on high power. Do the magnetrons lose power over time or do I have another issue. Thanks for the help Mike Ads By Google Related Models |
Hi.
Yes, the magnetron may lose the power over the time. Please provide the complete model number. Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
The microwave you have is using an inverter power board, which is no longer available. The chance that it's the magnetron is 50/50. Try to replace it. If it will work - you are lucky. The good think that you can return any parts even if they been installed. The magnetron Part number: 487757 Here are the breakdown diagram and Microwave parts & food cavity replacement parts for Thermador SMW272P BUILT-IN OVEN | AppliancePartsPros.com Good luck. Post the results. Simon.
__________________
You are welcome.
Simon.
__________________
| Display Modes | |
| Compressor PSI output? | Mickstix | Refrigerator & Freezer Repair | 3 | 05-02-2010 09:38 PM |
| Low water output from GE Refrig | DGS | Refrigerator & Freezer Repair | 3 | 04-29-2010 04:43 AM |
| leak at water output into tub | aknobel | Washer Repair | 5 | 09-17-2009 11:40 AM |
| Low burner output | bdelaney | Oven Repair (including Ranges and Cooktops) | 1 | 11-03-2008 05:10 PM |
| Low motor power output | DrHP | Dryer Repair | 0 | 11-20-2007 09:15 AM |
