Discuss
no heat
 in
Microwave Repair
hi voltage is present but no heat. all interlock switches open/close and seem ok. motors run lights are on, timer
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » no heat
  #1 (permalink)
Old 04-17-2012, 07:42 AM
Junior Member
ecreek is on a distinguished road
Default no heat
Model Number: mwm-17668   Brand: White-Westinghouse   Age: 5 - 10 years
hi voltage is present but no heat. all interlock switches open/close and seem ok. motors run lights are on, timer times outs normally. ne body know how i can check the magnetron?
Ads By Google
Related Models
Amana MWP211 MWAVE- CNTRTP / STAND ALONE
Amana MWR212 MWAVE- CNTRTP / STAND ALONE
Amana MWR213 MWAVE- CNTRTP / STAND ALONE
Amana MWR214 MWAVE- CNTRTP / STAND ALONE
Amana MWR365 MWAVE- CNTRTP / STAND ALONE
Amana MWR36510 MWAVE- MOUNTED OVER RANGE/WO
Frigidaire MWS445RES0 Frg(v1) / Washer
Frigidaire MWS445RES1 Frg(v0) / Washer
Frigidaire MWS445RES2 Frg(v0) / Washer
Frigidaire MWS445RET0 Frg(v2) / Washer
Frigidaire MWS445RFS0 Frg(v0) / Washer
Frigidaire MWS445RFS1
Frigidaire MWS445RFS2 Frg(v0) / Washer
Frigidaire MWS833AS2 Universal/washer
Amana MWT344/1001 MWAVE - FAMILY SIZE (60 HZ)
Amana MWT366/1001 MWAVE - FAMILY SIZE (60 HZ)
Amana MWT4441D MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4451D MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4451D01 MWAVE - FAMILY SIZE (60 HZ)
 MWT4451WW MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4451WW01 MWAVE - FAMILY SIZE (60 HZ)
Amana MWT4461D MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4461WW MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4661D MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4661W MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4661WW MWAVE- MOUNTED OVER RANGE/WO
Frigidaire MWV150KBA MICROWAVE
Frigidaire MWV150KWA MICROWAVE
Frigidaire MWX111REW0 Frg(v0) / Washer
Frigidaire MWX111REW1 Frg(v0) / Washer
Frigidaire MWX111REW2 Frg(v0) / Washer
Frigidaire MWX111REW3 Frg(v0) / Washer
Frigidaire MWX121RBD0 Frg(v2) / 27 " Washer
Frigidaire MWX121RBD2 Frg(v1) / Washer
Frigidaire MWX121RBD3 Frg(v1) / Washer
Frigidaire MWX121RBW1 Frg/27" Washer
Frigidaire MWX121RBW2 Frg(v2) / Washer
Frigidaire MWX121RBW3 Frg(v2) / Washer
Frigidaire MWX121RBWD0 Kel(v10) / 27 " Washer
Frigidaire MWX121RBWL0 Frg(v2) / 27 " Washer
Frigidaire MWX121RBWW0 Frg(v1) / 27 " Washer
Frigidaire MWX121REW0 Frg(v0) / Washer
Frigidaire MWX121REW1 Frg(v0) / Washer
Frigidaire MWX121REW2 Frg(v0) / Washer
Frigidaire MWX121REW3 Frg(v0) / Washer
Frigidaire MWX121REW4 Washer - Universal
Frigidaire MWX223RED0 Frg(v1) / Washer
Frigidaire MWX223RED1 Frg(v1) / Washer
Frigidaire MWX223RED2 Frg(v1) / Washer
Frigidaire MWX223REW0 Frg(v2) / Washer
Frigidaire MWX223REW1 Frg(v2) / Washer
Frigidaire MWX223REW2 Frg(v2) / Washer
Frigidaire MWX223REW3 RESIDENTIAL WASHER
Frigidaire MWX233MBD0 Frg(v2) / 27 " Washer
Frigidaire MWX233MBD2 Frg(v1) / Washer
Frigidaire MWX233MBD3 Frg(v1) / Washer
Frigidaire MWX233MBW0 Tap(v4) / 27 " Washer
Frigidaire MWX233MBW1 Frg/27" Washer
Frigidaire MWX233MBW2 Frg(v2) / Washer
Frigidaire MWX233MBW3 Frg(v2) / Washer
Frigidaire MWX233MBWD0 Kel(v10) / 27 " Washer
Frigidaire MWX233MBWW0 Frg(v1) / 27 " Washer
Frigidaire MWX233RBD0 Frg(v4) / 27 " Washer
Frigidaire MWX233RBD2 Frg(v3) / Washer
Frigidaire MWX233RBD3 Frg(v3) / Washer
Frigidaire MWX233RBW1 Frg/27" Washer
Frigidaire MWX233RBW2 Frg(v4) / Washer
Frigidaire MWX233RBW3 Frg(v4) / Washer
Frigidaire MWX233RBWD0 Gib(v12) / 27 " Washer
Frigidaire MWX233RBWW0 Gib(v11) / 27 " Washer
Frigidaire MWX233RED0 Frg(v1) / Washer
Frigidaire MWX233RED1 Frg(v1) / Washer
Frigidaire MWX233RED2
Frigidaire MWX233RED3 Frg(v1) / Washer
Frigidaire MWX233RES0 Frg(v0) / Washer
Frigidaire MWX233RES1 Frg(v2) / Washer
Frigidaire MWX233RES2 Frg(v0) / Washer
Frigidaire MWX233RES3 Gib(v2)
Frigidaire MWX233RES4 Frg(v0) / Washer
Frigidaire MWX233RES5 RESIDENTIAL WASHER
Frigidaire MWX233REW0 Frg(v2) / Washer
Frigidaire MWX233REW1 Frg(v3) / Washer
Frigidaire MWX233REW2
Frigidaire MWX233REW3 Frg(v2) / Washer
Frigidaire MWX411REW0 Frg(v0) / Washer
Frigidaire MWX413REW0 Frg(v0) / Washer
Frigidaire MWX413REW1 Frg(v0) / Washer
Frigidaire MWX433RED0 Frg(v1) / Washer
Frigidaire MWX433RED1 Frg(v1) / Washer
Frigidaire MWX433RED2 Frg(v1) / Washer
Frigidaire MWX433RED3 Frg(v1) / Washer
Frigidaire MWX433REW0 Frg(v2) / Washer
Frigidaire MWX433REW1 Frg(v2) / Washer
Frigidaire MWX433REW2 Frg(v2) / Washer
Frigidaire MWX433REW3 Frg(v2) / Washer
Frigidaire MWX445MBD0 Frg(v3) / 27 " Washer
Frigidaire MWX445MBD2 Frg(v1) / Washer
Frigidaire MWX445MBD3 Frg(v2) / Washer
Frigidaire MWX445MBD4 Frg(v1) / Washer
Frigidaire MWX445MBW0 Tap(v7) / 27 " Washer
Frigidaire MWX445MBW1 Frg/27" Washer
Frigidaire MWX445MBW2 Frg(v3) / Washer
Frigidaire MWX445MBW3 Frg(v4) / Washer
Frigidaire MWX445MBW4 Frg(v2) / Washer
Frigidaire MWX445MBWD0 Gib(v10) / 27 " Washer
Frigidaire MWX445MBWO Frg(v1) / 27 " Washer
Frigidaire MWX445MBWW0 Frg(v1) / 27 " Washer
Frigidaire MWX445RBD0 Frg(v4) / 27 " Washer
Frigidaire MWX445RBD2 Frg(v5) / Washer
Frigidaire MWX445RBD4 Frg(v3) / Washer
Frigidaire MWX445RBW0 Tap(v8) / 27 " Washer
Frigidaire MWX445RBW1 Frg/27" Washer
Frigidaire MWX445RBW2 Frg(v6) / Washer
Frigidaire MWX445RBW3 Frg(v5) / Washer
Frigidaire MWX445RBW4 Frg(v4) / Washer
Frigidaire MWX445RBWW0 Gib(v11) / 27 " Washer
Frigidaire MWX645RES0 Frg(v1) / Washer
  #2 (permalink)
Old 04-17-2012, 09:17 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
You can check the magnetron for continuity with a multimeter.
You can also check to make sure it's not grounded.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 04-19-2012, 07:09 AM
Junior Member
Default no heat
thanks for the reply. what resistance values would i be looking for?
  #4 (permalink)
Old 04-23-2012, 08:59 AM
Junior Member
Default mwm-17668 no heat
i checked the magnetron filament. it measured .1 ohm. the hi voltage measured 3kV on an analog meter. all suggestions welcome.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
