AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Microwave door handle replacement -- screw makes removing inner panel difficult
Hi. The door handle broke on the microwave and I've read several threads on how to replace it. (Great information, by the way!) Unfortunately, there is a screw on the inner panel that makes it impossible to remove by the method shown in the video. I'm not sure if someone else fixed it incorrectly? The screw is attached to a (broken) piece of plastic and won't unscrew. Does anyone have advice on how to replace the door handle in this situation? Thank you! orelsie attached the following image(s):
Microwave Repair
