Discuss
Turntable Motor- equivalent spec question
 in
Microwave Repair
I have a microwave with a broken turntable motor (output shaft broke off.) I found another GE microwave in a
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Turntable Motor- equivalent spec question
  #1 (permalink)
Old 08-24-2009, 05:37 PM
Junior Member
stolichnaya1415 is on a distinguished road
Default Turntable Motor- equivalent spec question
Brand: GE   Age: 1 - 5 years
I have a microwave with a broken turntable motor (output shaft broke off.) I found another GE microwave in a trash pile and salvaged its turn table motor out of it. Before I put the motor in my microwave, however, I need to know if the parts are compatible. The original motor had these specs: AC21V 50/60Hz 2.5/3 r.p.m. 3W P/N 6549W15017A The salvaged motor has these specs: AC 120V 60Hz 6 r.p.m 2.8W P/N 6549W1S013A Obviously, I don't want to use a motor that has a significantly different rated power input, as this could result in potentially dangerous electrical problems. The AC21V 3W vs. AC 120V 2.8 W has me concerned. I assume AC21V is short for AC210V? As in, it uses regular wall voltage? I don't understand how such similar parts could differ so strongly in voltage. Is 2.8W significantly different enough from 3W that this could pose a concern? I appreciate any advice.
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Turntable Motor (drive vs. stirrer) PoggiPJ Microwave Repair 7 07-02-2009 10:37 PM
How to replace turntable Motor pegsue62 Microwave Repair 0 01-10-2009 12:35 PM
GE microwave turntable motor verndewitt Microwave Repair 1 10-20-2008 02:51 PM
How do I connect wires to turntable motor? ltml82 Microwave Repair 1 02-20-2008 04:37 PM
Buying the right microwave turntable motor rcollison Microwave Repair 2 02-01-2008 04:42 AM
