Discuss
Kenmore/GE Advantium 120 fan keeps running
 in
Microwave Repair
Just over a year old and out of warranty. We were using the convection part of the oven and the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Kenmore/GE Advantium 120 fan keeps running
  #1 (permalink)
Old 08-19-2009, 12:29 PM
Junior Member
verhoff is on a distinguished road
Default Kenmore/GE Advantium 120 fan keeps running
Brand: GE   Age: 1 - 5 years
Just over a year old and out of warranty. We were using the convection part of the oven and the whole thing just died. Sounds like a common defect with the unit.
Regardless, upon inspecting it, we had a blown cavity TCO. Replaced it today and everything seems to be back to normal except for 1 thing. The Exhaust Fan keeps running. On the control I can turn it "on" and adjust it to high and low fan settings and it speeds up and down. But if I press to turn off the fan it still runs (at sub-low) speed.
The GE service manual says to replace the PCB but I think it's something else like a relay or some other part that got fried when the fuse blew. Any help would be greatly appreciated. Thanks.
Ads By Google
  #2 (permalink)
Old 08-19-2009, 03:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This fan should run every time when the speed cook is in use. If it runs while everything is off then check a fan thermostat (somewhere on the bottom panel from inside of the microwave control compartment).
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-19-2009, 03:45 PM
Junior Member
Default picture....
Would you be referring to what's on the service manual as a thermister? In the center of the picture. What I replaced was the cavity tco just to the left of it. Thanks again, Dennis
  #4 (permalink)
Old 08-19-2009, 11:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
No. It should be on the bottom, not on the top of the microwave because it senses the bottom panel temperature heated by a stove under the microwave.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dead! Kenmore Elite -Advantium 120 nmpinnyc Microwave Repair 71 05-15-2012 06:17 PM
Kenmore Oven Running Hot pinhoti Oven Repair (including Ranges and Cooktops) 3 10-29-2009 07:05 AM
Kenmore Advantium 120 won't turn off speedcook FIRE HAZARD - HELP! homerwalker Microwave Repair 1 09-21-2009 01:32 PM
Kenmore.. fan running but not cooling.. ultimix Refrigerator & Freezer Repair 1 12-19-2008 08:33 AM
Dead Kenmore Elite Advantium Microwave beckon36 Microwave Repair 3 02-29-2008 03:13 PM
