Been looking through all the past threads and didn't see any full response to dead MWave. I have the panel off and the switches on my door latch mechanism aren't the same as in the parts list. I don't have a switch with a fuse attached. Instead of two "door switches" I have three.
Top to bottom here is what they read:
Switch - Door Open - Door Closed
Top ----- open --------closed Mid ----- closed -------open Bottom - open -------closed
Have the same problem as many others have lights and control panel functions with no fans or magnatron.
Thanks in advance:o
Clint
Finally got the Tech Spec sheet and found the "door Switches" are actually sensing switch on top; Monitor switch in center; and secondary switch on bottom. All appear to be functioning correctly as to tech sheet. Next question is: Is the 20 amp fuse a slow blow or a simple fuse? I am getting continuity end to end.
