Discuss
Dead! Kenmore Elite -Advantium 120
 in
Microwave Repair
I'm glad you were able to fix it. Gene.
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Dead! Kenmore Elite -Advantium 120
  #21 (permalink)
Old 02-04-2008, 12:44 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #22 (permalink)
Old 06-02-2008, 05:30 PM
osgoodrp osgoodrp is offline
Junior Member
osgoodrp is on a distinguished road
Default
Hi Gene,
I have a very similar issue with our advantium oven. Using the convection oven part and it just died in the middle of cooking. I found the diagram and it's the same as Nick's. My issue is how do I test the fuse (assuming I find it) and I can't see the diagrams linked to your post.
  #23 (permalink)
Old 06-02-2008, 09:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Click on any diagram link on page 1 and type your model number in the search box. You'll get all break down diagrams.
After you locate the fuse just check it for continuity (remove the wires first).
__________________
  #24 (permalink)
Old 06-03-2008, 05:55 PM
Junior Member
Default
Thanks. Pulled the fuse and it's showing 0 on VOM, so I ordered the cavity thermocouple.
  #25 (permalink)
Old 06-05-2008, 01:47 PM
Junior Member
Default
Got the part and installed it, we're back in business.
Many thanks from a greatful wife also.
  #26 (permalink)
Old 06-05-2008, 02:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #27 (permalink)
Old 08-24-2008, 02:28 PM
FlockWSO FlockWSO is offline
Junior Member
FlockWSO is on a distinguished road
Default
I'm glad I found this forum! I also have a dead Kenmore Elite Advantium 120 - Model 363.63699301. I understand this model may be different than those already mentioned in this thread, but after looking at the diagrams they appear fairly similar.
Anyway, I was using the convection oven when it just stopped - no display, no light, nothing. The power going to the oven power cord checks ok, so the issue is within the unit.
Based on the previous repairs in this thread, it looks like I need to take the unit off the wall, check the fuse, and if the fuse is ok I should replace the themocoupler, right? Based on my parts list and diagrams, I see a "TCO, Oven Cavity" and a "TCO, Base Hood." Is the Oven Cavity the one I should repace? Is there a way to bench check a TCO? With a manual and some tools I am fairly handy with disassembly/assembly, but I can certainly use a primer on how the parts work together.
Any help is appreciated!
  #28 (permalink)
Old 09-07-2008, 05:23 PM
Junior Member
Default
Well, even though I didn't get a reply here, I took the plunge and bought the TCO. Taking the oven off the wall and then tearing into it wasn't fun, but the "operation" was ultimately successful. There certainly were a lot of layers to disassemble to get to the part I needed to swap, but in the end it was pretty straight forward.
So thanks for the previous postings here - it gave me the confidence to perform this surgery on my own!
  #29 (permalink)
Old 09-08-2008, 10:44 AM
kenmoreuser1 kenmoreuser1 is offline
Junior Member
kenmoreuser1 is on a distinguished road
Default Same problem. Dead while using convection
After reviewing all the issues here, it should steamline my troubleshooting. I'll post if it works.
Thanks All
  #30 (permalink)
Old 10-12-2008, 03:47 PM
Strummer Strummer is offline
Junior Member
Strummer is on a distinguished road
Default
I have the same issue, do I have to take it of the wall to check the fuse?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noisy Kenmore elite achrispyfinn Dishwasher Repair 1 04-25-2008 07:18 PM
Opening Up A Kenmore Elite jmatlin Washer Repair 2 01-06-2008 03:49 PM
Kenmore Elite Dryer Karen Lomba Dryer Repair 2 12-31-2007 09:23 AM
Problems with Kenmore Elite kidao35 Dryer Repair 3 11-02-2007 04:33 AM
Kenmore Elite E1 Sensor collins66 Dryer Repair 3 10-05-2007 02:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
