Discuss
Need help locating thermostat
 in
Microwave Repair
Hi, between the off brand and the age (mfg date Nov 1989) I'm not expecting miracles; but if someone
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Need help locating thermostat
  #1 (permalink)
Old 01-15-2008, 09:55 PM
Hilusi Hilusi is offline
Junior Member
Hilusi is on a distinguished road
Default Need help locating thermostat
Model Number: MM0166   Brand: Modern Maid   Age: More than 10 years
Hi, between the off brand and the age (Manufacturer date Nov 1989) I'm not expecting miracles; but if someone could help me locate the thermostat on my microwave I'd really appreciate it. It is an over-the-range Microwave and we are hoping to get another year or two out of it. Everything works: clock, fan, lights; but no "micro waves". When we turn it on, no sound - the timer just counts down. I assume that is textbook thermostat. I found the Buss fuse (250V, 15Amp) and will replace that as well; but I can't locate (or at least identify) the thermostat. Any suggestions?
Related Models
Amana MM2000C Commercial Microwaves
Menu Master MM2000C  Commercial Microwaves
Amana MM2000CS Commercial Microwaves
Amana MM2230C Commercial Microwaves
Amana MM2230CS Commercial Microwaves
Amana MM659E Mwave - Cntrtp / Stand Alone
Amana MM659W Mwave - Cntrtp / Stand Alone
Maytag MMA27B Misc / Accessory
Maytag MMA27Q Misc / Accessory
Maytag MMA27W Misc / Accessory
Maytag MMA30B Misc / Accessory
Maytag MMA30Q Misc / Accessory
Maytag MMA30W Misc / Accessory
Bosch MMB9110 UC/03 (FD 8110 -)
International MMC1500CGE Ref - Top Mount
Maytag MMC5000ADB Mwave - Mounted Under Cabinet
Maytag MMC5000ADW Mwave - Mounted Under Cabinet
Maytag MMC5000BDB Mwave - Mounted Under Cabinet
Maytag MMC5000BDQ Mwave - Mounted Under Cabinet
Maytag MMC5000BDW Mwave - Mounted Under Cabinet
Maytag MMC5080AAB Mwave - Cntrtp / Stand Alone
Maytag MMC5080AAS Mwave - Cntrtp / Stand Alone
Maytag MMC5080AAW Mwave - Cntrtp / Stand Alone
Maytag MMC5086AAB Mwave - Cntrtp / Stand Alone
Maytag MMC5086AAQ Mwave - Cntrtp / Stand Alone
Maytag MMC5086AAS Mwave - Cntrtp / Stand Alone
Maytag MMC5086AAW Mwave - Cntrtp / Stand Alone
Maytag MMC5193AAB Mwave - Cntrtp / Stand Alone
Maytag MMC5193AAQ Mwave - Cntrtp / Stand Alone
Maytag MMC5193AAS Mwave - Cntrtp / Stand Alone
Maytag MMC5193AAW Mwave - Cntrtp / Stand Alone
International MMD1700CGE Ref - Top Mount
Whirlpool MME08XW0
Whirlpool MME08XW1
Amana MMO166 Mwave - Mounted Over Range/wo
Amana MMO166/101W Mwave - Family Size (60 Hz)
Amana MMO16610 Mwave - Family Size (60 Hz)
Amana MMO166MN002 Range - S/c S/i Ddraft Gas
Amana MMO219 Mwave - Cntrtp / Stand Alone
Amana MMO2661D Mwave - Mounted Over Range/wo
Amana MMO2661W Mwave - Mounted Over Range/wo
Amana MMO2671D01 Mwave - Family Size (60 Hz)
Amana MMO2671WW01 Mwave - Family Size (60 Hz)
Maytag MMV1153AAB Mwave - Mounted Over Range/wo
Maytag MMV1153AAW Mwave - Mounted Over Range/wo
Maytag MMV1153BAB Mwave - Mounted Over Range/wo
Maytag MMV1153BAQ Mwave - Mounted Over Range/wo
Maytag MMV1153BAS Mwave - Mounted Over Range/wo
Maytag MMV1153BAW Mwave - Mounted Over Range/wo
Maytag MMV4184AAB Mwave - Mounted Under Cabinet
Maytag MMV4184AAQ Mwave - Mounted Under Cabinet
Maytag MMV4184AAW Mwave - Mounted Under Cabinet
Maytag MMV4205AAB Mwave - Mounted Over Range/wo
Maytag MMV4205AAQ Mwave - Mounted Over Range/wo
Maytag MMV4205AAS Mwave - Mounted Over Range/wo
Maytag MMV4205AAW Mwave - Mounted Over Range/wo
Maytag MMV4205BAB Mwave - Mounted Over Range/wo
Maytag MMV4205BAQ Mwave - Mounted Over Range/wo
Maytag MMV4205BAS Mwave - Mounted Over Range/wo
Maytag MMV4205BAW Mwave - Mounted Over Range/wo
Maytag MMV5000ADA Mwave - Mounted Under Cabinet
Maytag MMV5000ADB Mwave - Mounted Under Cabinet
Maytag MMV5000ADW Mwave - Mounted Under Cabinet
Maytag MMV5000BAB Mwave - Mounted Under Cabinet
Maytag MMV5000BAC Mwave - Mounted Under Cabinet
Maytag MMV5000BAQ Mwave - Mounted Under Cabinet
Maytag MMV5000BAW Mwave - Mounted Under Cabinet
Maytag MMV5000BDB Mwave - Mounted Under Cabinet
Maytag MMV5000BDC Mwave - Mounted Under Cabinet
Maytag MMV5000BDQ Mwave - Mounted Under Cabinet
Maytag MMV5000BDW Mwave - Mounted Under Cabinet
Maytag MMV5100AAB Mwave - Mounted Under Cabinet
Maytag MMV5100AAQ Mwave - Mounted Under Cabinet
Maytag MMV5100AAS Mwave - Mounted Under Cabinet
Maytag MMV5100AAW Mwave - Mounted Under Cabinet
Maytag MMV5156AAB Mwave - Mounted Under Cabinet
Maytag MMV5156AAQ Mwave - Mounted Under Cabinet
Maytag MMV5156AAS White Westinghouse/refrigerator
Maytag MMV5156AAW Mwave - Mounted Under Cabinet
Maytag MMV5156ACB Mwave - Mounted Under Cabinet
Maytag MMV5156ACQ Mwave - Mounted Under Cabinet
Maytag MMV5156ACS Mwave - Mounted Under Cabinet
Maytag MMV5156ACW Mwave - Mounted Under Cabinet
Maytag MMV5165AAB Mwave - Mounted Over Range/wo
Maytag MMV5165AAQ Mwave - Mounted Over Range/wo
Maytag MMV5165AAS Mwave - Mounted Over Range/wo
Maytag MMV5165AAW Mwave - Mounted Over Range/wo
Maytag MMV5165BAB Mwave - Mounted Over Range/wo
Maytag MMV5165BAQ Mwave - Mounted Over Range/wo
Maytag MMV5165BAS Mwave - Mounted Over Range/wo
Maytag MMV5165BAW Mwave - Mounted Over Range/wo
Maytag MMV5186AAB Mwave - Mounted Under Cabinet
Maytag MMV5186AAQ Mwave - Mounted Under Cabinet
Maytag MMV5186AAS Mwave - Mounted Under Cabinet
Maytag MMV5186AAW Mwave - Mounted Under Cabinet
Maytag MMV5186ACB Mwave - Mounted Under Cabinet
Maytag MMV5186ACQ Mwave - Mounted Under Cabinet
Maytag MMV5186ACS Mwave - Mounted Under Cabinet
Maytag MMV5186ACW Mwave - Mounted Under Cabinet
Maytag MMV5207AAB Mwave - Mounted Over Range/wo
Maytag MMV5207AAQ Mwave - Mounted Over Range/wo
Maytag MMV5207AAS Mwave - Mounted Over Range/wo
Maytag MMV5207AAW Mwave - Mounted Over Range/wo
Maytag MMV5207ACB Mwave - Mounted Over Range/wo
Maytag MMV5207ACQ Mwave - Mounted Over Range/wo
Maytag MMV5207ACS Mwave - Mounted Over Range/wo
Maytag MMV5207ACW Mwave - Mounted Over Range/wo
Maytag MMV5207BAB Mwave - Mounted Over Range/wo
Maytag MMV5207BAQ Mwave - Mounted Over Range/wo
Maytag MMV5207BAS Mwave - Mounted Over Range/wo
Maytag MMV5207BAW Mwave - Mounted Over Range/wo
Maytag MMV5207BCB Mwave - Mounted Over Range/wo
Maytag MMV5207BCQ Mwave - Mounted Over Range/wo
Maytag MMV5207BCS Mwave - Mounted Over Range/wo
Maytag MMV5207BCW Mwave - Mounted Over Range/wo
Maytag MMV6178AAB Microwave - Convection
  #2 (permalink)
Old 01-16-2008, 05:32 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Most likely the problem is one of the door switches.
You can access them after open the control panel.
- Here are the break down diagrams for the Modern Maid microwave Model MMO166
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermostat or... PeggySue Heating, Ventilation, and Air Conditioning (HVAC) 1 11-30-2007 02:31 PM
Thermostat or... PeggySue Heating, Ventilation, and Air Conditioning (HVAC) 0 11-29-2007 10:26 PM
Need new thermostat nyan42 Oven Repair (including Ranges and Cooktops) 3 11-21-2007 02:51 PM
new thermostat replacement deronsherry Oven Repair (including Ranges and Cooktops) 0 10-05-2007 07:41 AM
problem with thermostat dav5 Oven Repair (including Ranges and Cooktops) 1 09-30-2007 01:55 AM
