Discuss
Litton Microwave No Power Failure
 in
Microwave Repair
Hello, My Litton Generation II combination Microwave/oven just failed. The convention Oven works fine, however, the microwave does not work
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Litton Microwave No Power Failure
  #1 (permalink)
Old 08-17-2009, 05:23 PM
Junior Member
Bob B is on a distinguished road
Default Litton Microwave No Power Failure
Model Number: Litton Generation II Combination Microwave/Oven   Brand: -other-   Age: More than 10 years
Hello,
My Litton Generation II combination Microwave/oven just failed. The convention Oven works fine, however, the microwave does not work at all. The clock and all power is shut down. I checked the circuit breakers and they are all on. I also opened the glass cover plate and changed the screw-in fuse. That did not work.
I recall having a similar problem several years ago, and a forum such as this helped me identify an internal component. I believe (but not sure) that it was a diode. I ordered and replaced the part as instructed and the unit has worked since. I believe I am experiencing the same problem.
Does anyone have any experience with this and do you know the part I am referring. If so, please advise.
Thanks,
Bob B.
Ads By Google
Related Models
Whirlpool LJD1306LQ0
Whirlpool LJD1306LT0
Bosch LK100-010
Bosch LK100-020
Bosch LK100-110
Bosch LK100-120
Bosch LK320-010
Bosch LK320-020
Bosch LK320-030
Bosch LK400-010
Bosch LK400-020
Bosch LK400-030
Amana LKG-170 Room Air Conditioner
Amana LKG-171 Room Air Conditioner
Amana LKG-240 Room Air Conditioner
Amana LKG-240H Room Air Conditioner
Amana LKG-241 Room Air Conditioner
Amana LKG-241H Room Air Conditioner
Amana LKG-300 Room Air Conditioner
Amana LKG-300H Room Air Conditioner
Amana LKG-340 Room Air Conditioner
Amana LKG-340HE Room Air Conditioner
Amana LKG-341 Room Air Conditioner
Amana LKG-470 Room Air Conditioner
Amana LKG-470HE Room Air Conditioner
Amana LKG-471 Room Air Conditioner
Amana LKG-471HE Room Air Conditioner
Amana LKG-620 Room Air Conditioner
Amana LKG-621 Room Air Conditioner
Amana LKG601-617 Room Air Conditioner
Amana LKG601H-617 Room Air Conditioner
Amana LKI721 Range - F/s Std Gas
Amana LKU-617 Range - S/c S/i Ddraft Gas
Amana LKU-617A Range - S/c S/i Ddraft Gas
Bosch LL010-000
Whirlpool LLC7244AN0
Whirlpool LLC7244AQ0
Whirlpool LLC7244AW0
Whirlpool LLC7244AZ0
Whirlpool LLC7244BQ0
Whirlpool LLC7244BQ1
Whirlpool LLC7244BZ0
Whirlpool LLC7244BZ1
Whirlpool LLC8244DQ0
Whirlpool LLC8244DZ0
Whirlpool LLN8233BN0
Whirlpool LLN8233BN1
Whirlpool LLN8233BQ0
Whirlpool LLN8233BQ1
Whirlpool LLN8233BW0
Whirlpool LLN8233BW1
Whirlpool LLN8244AN0
Whirlpool LLN8244AW0
Whirlpool LLN8244BN0
Whirlpool LLN8244BW0
International LLR1100AJQ Range - F/s Std Gas
International LLR1100AJW Range - F/s Std Gas
International LLR1415AJS Range - F/s Std Gas
International LLR1415AJW Range - F/s Std Gas
International LLR4451AJS Range - F/s Std Gas
International LLR4451AJW Range - F/s Std Gas
Whirlpool LLR5144BQ0
Whirlpool LLR5144BQ1
Whirlpool LLR5144BW0
Whirlpool LLR6144AN0
Whirlpool LLR6144AQ0
Whirlpool LLR6144AW0
Whirlpool LLR6144BN0
Whirlpool LLR6144BN1
Whirlpool LLR6144BQ0
Whirlpool LLR6144BQ1
Whirlpool LLR6144BW0
Whirlpool LLR6144BW1
Whirlpool LLR6233AN0
Whirlpool LLR6233AN1
Whirlpool LLR6233AQ0
Whirlpool LLR6233AW0
Whirlpool LLR6233AW1
Whirlpool LLR7144DQ0
Whirlpool LLR7144DW0
Whirlpool LLR7144DZ0
Whirlpool LLR8233BN0
Whirlpool LLR8233BN1
Whirlpool LLR8233BQ0
Whirlpool LLR8233BQ1
Whirlpool LLR8233BW0
Whirlpool LLR8233BW1
Whirlpool LLR8233DQ0
Whirlpool LLR8233DW0
Whirlpool LLR8233DZ0
Whirlpool LLR8233EQ0
Whirlpool LLR8233EQ1
Whirlpool LLR8233EZ0
Whirlpool LLR8233EZ1
Whirlpool LLR8245AG0
Whirlpool LLR8245AN0
Whirlpool LLR8245AW0
Whirlpool LLR8245BN0
Whirlpool LLR8245BN1
Whirlpool LLR8245BW0
Whirlpool LLR8245BW1
Whirlpool LLR8245DQ0
Whirlpool LLR8245DZ0
Whirlpool LLR9245AQ0
Whirlpool LLR9245BQ0
Whirlpool LLR9245BQ1
Whirlpool LLR9245DQ0
Whirlpool LLR9245DZ0
Whirlpool LLT7144AN0
Whirlpool LLT7144AQ0
Whirlpool LLT7144AW0
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AN1
Whirlpool LLT8233AQ0
Whirlpool LLT8233AQ1
  #2 (permalink)
Old 09-05-2009, 02:54 PM
Junior Member
mustarddog is on a distinguished road
Default Any solution?
My Litton Aire Generation II Microwave just did the exact same thing today. Did you ever find the answer to repair it? Just curious. Thanks.
  #3 (permalink)
Old 09-12-2009, 03:48 PM
Junior Member
bsl121 is on a distinguished road
Default Litton-Aire Generation II Microwave - no power
We just tried to fix my Mom's 1986 microwave that also has no power to light, fan and microwave. Would you let us know where the glass panel is to replace the fuse? We opened the control panel where the keypads were to the right and saw lots of wires but didn't see a fuse. Also we opened up under where the light and filter are.
Any help will be appreciated. Also if you figure out where the diode is and what the part is, please let us know.
Thanks,
Wayne
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Litton Microwave taulbee Microwave Repair 0 05-06-2009 05:51 PM
Microwave total power failure ldmartin328 Microwave Repair 0 01-12-2009 12:57 PM
Broken Litton Microwave jlivermore Microwave Repair 0 09-24-2008 08:32 AM
Litton Commercial Microwave alf Microwave Repair 3 03-29-2008 12:23 PM
Litton microwave built in oven ferdshaw Microwave Repair 0 02-18-2008 09:05 PM
