| » Surface light is out |
Model Number: 721-80412500 Brand: Kenmore Age: 1 - 5 years
I changed both light bulbs, and it still did not light up when pressing the surface light button on the controller pad. What part should I buy to fix this problem? I appreciate your help very much and thanks for your time.
It could be a worn key on your touchpad.
No. This may sound dumb, but it is a very common thing...are you sure you didn't put the old bulb back in by mistake? If this is the problem, please don't embarrass yourself by admitting it; but it's a necessary question in a long distance attempt to diagnose. Does the light come on when you open the door? Did it before? Do you have a way of testing the outlet the M'wave is plugged into?
| Display Modes | |
| Hot Surface Indicator Light Does Not Light Up! Help! | musicew | Oven Repair (including Ranges and Cooktops) | 0 | 01-06-2010 10:14 PM |
| Hot Surface Indicator Light | bbrepair | Oven Repair (including Ranges and Cooktops) | 3 | 10-03-2009 05:01 AM |
| Surface light stays on | buyingjaxhouses | Oven Repair (including Ranges and Cooktops) | 1 | 09-08-2009 07:38 PM |
| Hot Surface Signal Light | Tigerest45 | Oven Repair (including Ranges and Cooktops) | 2 | 01-02-2009 05:55 PM |
| hot surface light will not go off | savoit01 | Oven Repair (including Ranges and Cooktops) | 2 | 12-19-2008 08:00 PM |
