I have a ge microwave that has had 220v ran throgh it because somebody wired a generator wrong. The smart board was fried transformer resistors burnt up everything else looked good. Door switches fuse all check out. I told the guy the board was expensive and other problems could be looming. He said change it I did and still nothing works I have voltage at the in side of smartboard transformer and coming out I have it at the door swtches I have no display nothing works. My question is, is the touch panel bad I dont want to change it but the customer is sure it will fix it. How can I be sure? Thanks.
