Ihave a SAMSUNG over the range microwave that shuts off. It will run for 1-5 minutes then shuts off and the entire display lites. I can depress the cancel button and it resets the M/W but the problem persists. The problem seems to be progressive, i.e it happens more frequently and sooner as time goes on.
When the unit shuts of the display immediately shows all 8's (88888)
I have already replaced the control panel...did not solve prolem. All of the switches and TCO's appear to test good. My next thought is the control pad, however, I don't know how to test it.
Could the problem be with the HV capacitor or the magnetron?
I have another unit doing the same thing however this one now shuts off immediatley.
Could not locate the tech sheet (isn't it normally in with the control panel?), which would probably help.
thanks, chris
