A white ribbon material is loose inside GE JTP86sof1SS microwave door. How do I reattach or replace it? Picture attached showing issue. Thx! UPDATE: Was able to use putty knife and screw driver to gently pry door apart. (There is another video post about taking doors apart which helps although this one is different with plastic tabs.) The white ribbon is from double sided tape! GE did not remove it on original assembly so of course over time in settled out since not hard press fit. Stop it GE! dolson9835 attached the following image(s):
