Discuss
cook top lights on whirlpool micro hood
 in
Microwave Repair
A bit of googling indicates that the lights on these units tend to be a common problem. Mine were fine
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » cook top lights on whirlpool micro hood
  #1 (permalink)
Old 01-03-2012, 06:51 PM
Junior Member
gudlife is on a distinguished road
Default cook top lights on whirlpool micro hood
Model Number: board 4359414   Brand: Whirlpool   Age: 5 - 10 years
A bit of googling indicates that the lights on these units tend to be a common problem. Mine were fine until the other day when we had a power outage. I'm guessing the inrush surge popped the board. Everything else on the unit works fine.
The simple answer is to replace the board...at roughly the cost of a new unit. Kind of steep just to fix my wife's favorite night light.
I was thinking of breaking out the soldering iron and replacing what I figured would be a faulty relay. Now I am looking at the wiring diagram and I see some notation that is new to me.
Anybody done a board level repair on one of these?
The mico controller side of the circuit seems to function fine. The turntable and fan controls function and the unit beeps when I hit the lights button. The wiring diagram shows standard relays for the turntable and the vent, but the lights show up as attached to PH1 and VR2. I can't find any notation on what PH stands for anywhere? The resistor I'm guessing has something to do with the dual brightness modes. Any thoughts?
Related Models
Amana BP22A2E REF - BOTTOM MOUNTS
Amana BP22A2L REF - BOTTOM MOUNTS
Amana BP22AW REF - BOTTOM MOUNTS
 BP6000ER Air Conditioner
Whirlpool BPAC0500AS0 AIR CONDITIONERS
Whirlpool BPAC0500AS1 Air-conditioner/heat pump
Whirlpool BPAC0500AS2 AIR CONDITIONER
Whirlpool BPAC0500AS3 AIR CONDITIONER
Whirlpool BPAC0500FS0 AIR CONDITIONER
Whirlpool BPAC0700AS0 Air-conditioner/heat pump
Whirlpool BPAC0700AS1 AIR CONDITIONER
Whirlpool BPAC0700FS0
Whirlpool BPAC0830AS1 AIR CONDITIONER
Whirlpool BPAC0830AS2
Whirlpool BPAC1000AS0 AIR CONDITIONER
Whirlpool BPAC1000AS2 AIR CONDITIONER
Whirlpool BPAC1200AS0 Air-conditioner/heat pump
Whirlpool BPAC1200AS2 AIR CONDITIONERS
Whirlpool BPAC1200FS0 AIR CONDITIONERS
Whirlpool BPAC1230AS0 AIR CONDITIONER
Whirlpool BPAC1230AS2 AIR CONDITIONER
Whirlpool BPAC1400BS0 AIR CONDITIONER
Whirlpool BPAC1800AS0 AIR CONDITIONER
Whirlpool BPAC1800BS0 AIR CONDITIONER
Whirlpool BPAC1800BS1 AIR CONDITIONER
Whirlpool BPAC1800BS2 ROOM AIR CONDITIONER
Whirlpool BPAC1800FS0 AIR CONDITIONERS
Whirlpool BPAC1830AS1 AIR CONDITIONER
Whirlpool BPAC1830AS2 AIR CONDITIONER
Whirlpool BPAC2400AS0 Air-conditioner/heat pump
Whirlpool BPAC2400BS0 AIR CONDITIONER
Whirlpool BPAC2400BS2 AIR CONDITIONER
Whirlpool BPAC2400FS0 AIR CONDITIONERS
Whirlpool BPAC2530ES0 AIR CONDITIONERS
Whirlpool BPDH2500AS0 DEHUMIDIFIER
Whirlpool BPDH2500AS1 DEHUMIDIFIER
Whirlpool BPDH2500AS2 DEHUMIDIFIER
Whirlpool BPDH2500FS0 DEHUMIDIFIER
Whirlpool BPDH4000AS1 DEHUMIDIFIER
Whirlpool BPDH4000AS2 DEHUMIDIFIER
Whirlpool BPDH4000AS3 DEHUMIDIFIER
Whirlpool BPDH4000FS0 DEHUMIDIFIER
Whirlpool BPDH5000BS1 DEHUMIDIFIER
Whirlpool BPDH5000BS2 DEHUMIDIFIER
Whirlpool BPDH5000FS0 DEHUMIDIFIER
Maytag BPNS24H9 REF - SXS/I&W
Maytag BPNS24H9A REF - SXS/I&W
Maytag BPNS24H9H REF - SXS/I&W
Amana BQ20RB REF - BOTTOM MOUNTS
Amana BQ20RBG REF - BOTTOM MOUNTS
Amana BQ20RBL REF - BOTTOM MOUNTS
Amana BQ20RBW REF - BOTTOM MOUNTS
Amana BR-20H REF - BOTTOM MOUNTS
Amana BR14 MISC / ACCESSORY
Amana BR14L MISC / ACCESSORY
Amana BR16E REF - BOTTOM MOUNTS
Amana BR16LE REF - BOTTOM MOUNTS
Amana BR18V1C REF - BOTTOM MOUNTS
Amana BR18V1E REF - BOTTOM MOUNTS
Amana BR18V1S REF - BOTTOM MOUNTS
Amana BR18V1W REF - BOTTOM MOUNTS
Amana BR18V2C REF - BOTTOM MOUNTS
Amana BR18V2E REF - BOTTOM MOUNTS
Amana BR18V2S REF - BOTTOM MOUNTS
Amana BR18V2W REF - BOTTOM MOUNTS
Amana BR18VC REF - BOTTOM MOUNTS
Amana BR18VE REF - BOTTOM MOUNTS
Amana BR18VL REF - BOTTOM MOUNTS
Amana BR18VSE REF - BOTTOM MOUNTS
Amana BR18VW REF - BOTTOM MOUNTS
Amana BR20J REF - BOTTOM MOUNTS
Amana BR20K REF - BOTTOM MOUNTS
Amana BR20M REF - BOTTOM MOUNTS
Amana BR20N REF - BOTTOM MOUNTS
Amana BR20QBL REF - BOTTOM MOUNTS
Amana BR20QBW REF - BOTTOM MOUNTS
Amana BR22S6E REF - BOTTOM MOUNTS
Amana BR22S6L REF - BOTTOM MOUNTS
Amana BR22S6W REF - BOTTOM MOUNTS
Amana BR22TE REF - BOTTOM MOUNTS
Amana BR22TL REF - BOTTOM MOUNTS
Amana BR22TW REF - BOTTOM MOUNTS
Amana BR22V1C REF - BOTTOM MOUNTS
Amana BR22V1E REF - BOTTOM MOUNTS
Amana BR22V1W REF - BOTTOM MOUNTS
Amana BR22VC REF - BOTTOM MOUNTS
Amana BR22VE REF - BOTTOM MOUNTS
Amana BR22VL REF - BOTTOM MOUNTS
Amana BR22VW REF - BOTTOM MOUNTS
  #2 (permalink)
Old 01-04-2012, 07:13 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
What notation?
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 01-04-2012, 09:42 AM
Junior Member
Default
All of the other components with relays were indicated as R and the lighting circuit had what looked like a relay marked as PH.
I pulled the board and PH apparently equals SSR solid state relay. Specifically a samsung S201DH2. The relay coupled with a Samwha svc 271-14 varistor is apparently what controls the current output to the lighting circuit for the 2 brightness settings.
I couldn't get any continuity through the varistor so I figured it might be dead. When I jumper around it my lights come on bright. Still no on/off function and no dim/bright (which I figured the varistor would be used for anyway).
Still not sure if I have a bad varistor, SSR or bad control input to the SSR. I found a pretty close varistor for around $2 from mouser and ******** has the SSRs for around $4. Guess I'll have to play with it some more-
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
20007 Micro Hood Installation SondraJo64 Microwave Repair 1 08-18-2011 11:55 AM
KA/Whirlpool Micro/Hood F2 Control Panel Error abby-grace Microwave Repair 3 03-25-2011 03:02 PM
Kenmore Micro Hood combo won't heat sweck Microwave Repair 0 11-23-2010 03:08 PM
Micro-Hood makes NOISE and DOESN'T COOk corns5 Oven Repair (including Ranges and Cooktops) 0 07-17-2010 10:52 AM
IKEA by Whirlpool 42" Range hood lights out liquidoranges Oven Repair (including Ranges and Cooktops) 8 08-19-2009 11:59 PM
