| » Won't heat |
Model Number: KCMS2055SSS-1 Brand: Kitchen Aid Age: 1 - 5 years
We bought this microwave 3/25/08 when we were remodeling our kitchen. I use it often and have had no problems. I used in on Saturday, July 4th and it worked fine. Later that evening when I was reheating some things, it would not heat. Everything else works. The turntable revolves, the light comes on and it sounds like it is running but it will not heat. We have unplugged it and plugged it back in and tried to heat a bowl of water. Still nothing. Do you have any ideas?
Related Models |
The problem could be a bad door switch or a bad control board. In order to perform the troubleshooting you have to have a simple multimeter.
Remove the microwave from the cabinet, remove the outer case and check the door switches for continuity as described in the Tech sheet. If there is nothing wrong then disconnect the wires from the high voltage primary windings and check for 120 VAC between those wires while the control calls for heat and the door is closed. If there is no proper voltage then the control board has to be replaced. If there is 120 VAC then the magnetron is a culprit. Post the results and we'll help you with the correct part numbers. Gene.
__________________
Professional appliance repair in Orange County, California. |
The wires must be disconnected otherwise the test result is inaccurate.
__________________
What is the complete model number of the microwave?
__________________
| Display Modes | |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 0 | 12-06-2009 01:58 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Normal Heat Empty, Heat Shuts Off Full | BigDaddyG | Dryer Repair | 4 | 08-06-2009 03:17 PM |
| No Heat While Turning, Heat When Stopped thou | msg2008 | Dryer Repair | 1 | 08-07-2008 05:08 AM |
