| » No power...is it fuse |
Model Number: Pnm1871sm3ss Brand: GE Age: 1 - 5 years
No power at all (no light or clock) is it a fuse? How hard to change, micro is wall mounted over stove
It may be the fuse, usually located behind the grille, between the door switches, or on the noise filter board.
Or it may be a thermal cutout / TCO/ thermostat mounted on the magnetron or on the oven cavity. There should be a technical sheet hidden behind your grille or controller. The tech sheet will show you where parts are. At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes. You can usually find helpful exploded views and order parts from the Pros here. . |
| Display Modes | |
| Suddenly no power, fuse tests fine | Timbert | Dryer Repair | 3 | 11-21-2011 01:26 PM |
| No power--maybe the fuse | nauzergirl | Microwave Repair | 3 | 05-26-2011 10:03 AM |
| Replaced thermal fuse, still no power | danthepainterman | Oven Repair (including Ranges and Cooktops) | 0 | 04-03-2011 09:53 AM |
| no power and it is not the fuse | Zeppelin737 | Microwave Repair | 0 | 02-22-2011 03:18 PM |
| GE Microwave - NO Power. Fuse? | SpartanGA | Microwave Repair | 5 | 02-07-2011 09:54 AM |
