Discuss
GE Profile Conv Oven - Interior Light Bulb Replace Help
 in
Microwave Repair
Interior light burned out. Cannot for the life of me find out how to access it to change. Viewed GE
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Profile Conv Oven - Interior Light Bulb Replace Help
  #1 (permalink)
Old 12-31-2007, 09:35 PM
Jamie Smalls Jamie Smalls is offline
Junior Member
Jamie Smalls is on a distinguished road
Default GE Profile Conv Oven - Interior Light Bulb Replace Help
Model Number: JVM1790SK01   Brand: GE   Age: 1 - 5 years
Interior light burned out. Cannot for the life of me find out how to access it to change. Viewed GE owners manual, but limited to exterior light bulb replacement. Please help. Thanks much in advance!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-15-2008, 12:07 AM
chuckles92104 chuckles92104 is offline
Junior Member
chuckles92104 is on a distinguished road
Default
Same here. Looks to be an omission in the manual.
After searching GE's site high and low I finally found some pitifully basic instructions which I've elaborated on here.
Bulb required: Manufactured by Aglaia for GE, 130V 35W Halogen bulb GE #WB08X10051 or equivalent.
There is a grille above the door and clock/cooking controls that extends the width of the unit. You need to remove this to get to the light receptacle. With the power to the unit off (unplug if you have access to it), get on a chair with a Phillips head screwdriver. Look down from the top and you will see two screws about 6" in from the ends. If you don't see the screws, open the cabinet doors above the unit (mine were blocking the screw heads). Remove the screws and set aside. Pull girlle towards you at the top being careful not to break the tabs at the position where the screws you just removed are located. After the tabs are out the grille should lift up (there are three hook-tabs along the bottom). Set it aside. Over toward the right you will see a smaller vertical grille. Just to the left of this there is a void with a Phillips head screw facing you. Remove the screw from the receptacle tab. Lift up the receptacle tab on the right. When the receptacle is clear on the right, move the receptacle to the right to release it from the tabs on the left. Lift the receptacle up until it clears the housing it just came from. Pull it gently toward you, rotate it bottom-toward you, and you will see the bulb to be replaced. My bulb was lightly held in using white silicone and removed easily by pulling it in the direction it was pointing. A word of caution about Halogen bulbs: When handling new bulbs be careful not to get any grease on them and handle them with clean cotton gloves or a clean t-shirt. Grease and oils from even clean hands will cause the bulb to burn out quickly. Replace the receptacle being careful to make sure the electrical wires are not pinched by the receptacle housing. Replace the screw; replace the grille; return power to the unit. You're done!
To find the bulb I Googled "General Electric WB08X10051" and "Lamp Halogen WB08X10051" and found options ranging in price from $8.10 to $10.71 ($13.50 with GE).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Electric Oven - Inside Light T&S KING Oven Repair (including Ranges and Cooktops) 3 06-30-2008 04:44 PM
Directions to Replace GE Profile Glass Cooktop jeanss Oven Repair (including Ranges and Cooktops) 0 11-30-2007 06:57 AM
replace oven light merv rotzien Oven Repair (including Ranges and Cooktops) 2 09-19-2007 01:45 PM
GE Profile Gas Oven will not light Don T. Oven Repair (including Ranges and Cooktops) 0 08-13-2007 04:40 PM
Microwave interior light bulb replacement Ardith Microwave Repair 4 07-26-2007 04:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
