| » Handle broken / Door Assembly cracked |
Model Number: JVM1870BFO2 Brand: GE Age: 1 - 5 years
Our GE Over-the-range microwave's handle broke few months ago on the bottom end. Using some glue, we were able to fix it. But this morning, the entire handle came off and in the process damaged the area where the screws get fastened.
The outer door frame is also cracked due to the heat from the stove below the microwave. Is it easy / safe to replace the entire door assembly (considering that the existing screw threads are damaged) or replace just the handle and some of the door parts like the outer door frame etc. Please also let me know whether this requires professional repair service or I can do it myself. Thanks Murali |
Quote:
Hi Murali and Stevde
If you can post the pictures of the door shown all damaged parts, it will help to find the best solution. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Hello Gene,
Thanks for looking into this issue. Have attached the pictures. Again the Model number of the Microwave is - JVM1870BFO2 I was wondering whether I should change the entire Door Assembly that includes the Handle and the door components (Drawing Reference #110 - as per the Exploded GE Parts diagram - attached as a pdf). The GE Part# is - WB56X10340. Again, thanks for your help, Gene. Murali |
Hi Murali,
Moneywise the entire door assembly is about 45 bucks more expensive. On other side there is a good possibility to break something else while working with the old door. The third option is to buy a new microwave. You should choose what is better to you. Best regards. Gene.
__________________
Hello Gene,
I ordered the Door assembly and just received it. How easy / difficult would be to fix this ?. My whole idea of buying the door assembly was to have an easier installation and also bcos the difference was just $40. Can you please let me know whether it is easy to remove the old door assembly and put the new one in ? (FYI, my earlier posting had the pictures). Thanks Murali |
Request to Mr.Gene and other users,
Could you please tell me or send any video clipping (if you have any) to replace the Microwave door assembly. I also would request you to confirm whether I need to do any leakage test. Thanks a lot for your help, Murali |
| Display Modes | |
| How do I replace a broken Kenmore Dryer Handle | Gina | Dryer Repair | 0 | 11-24-2007 01:20 PM |
| broken handle | bobdog | Microwave Repair | 0 | 11-24-2007 09:46 AM |
| Frigidaire Stainless Steel Handle Broken | cobra | Microwave Repair | 0 | 11-20-2007 01:56 PM |
| Door latch broken/Door locked | kitade | Dishwasher Repair | 2 | 10-23-2007 11:42 AM |
| Cracked my oven door window! | texasdiver | Oven Repair (including Ranges and Cooktops) | 3 | 09-15-2007 07:56 PM |
