| » Is it dead |
Quote:
Check and make sure both breakers are set and locked in place, and you have 220 / 240 VAC to the unit. especially if both the microwave and oven are "dead" or not working. If the problem is isolated to the microwave, it could be the inline fuse or a thermal limit switch. located behind the M/W control panel. You'll need to remove the top air grille, remove the screw attaching the control panel to the frame and lower it. You can then access the inline fuse and magnetron thermal fuse, make sure you turn the power off to the oven, and don't touch the capacitor, until you discharge the voltage build up. Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Dead | delarosa_zeke | Washer Repair | 1 | 04-28-2011 05:57 PM |
| dead | Tillerman | Dryer Repair | 4 | 04-22-2011 08:23 PM |
| dead? | mutt | Microwave Repair | 1 | 03-03-2011 01:56 PM |
| dead mw | n_sathya | Microwave Repair | 1 | 12-12-2007 04:51 PM |
| It's Dead Jim! | pconroy | Microwave Repair | 3 | 10-06-2007 06:31 PM |
