Discuss
bill summerville
 in
Microwave Repair
the replacement part i received for my microwave is the wrong temperature rating , the original thermostat rating is 150/0
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » bill summerville
  #1 (permalink)
Old 06-30-2009, 01:02 PM
Junior Member
summv is on a distinguished road
Default bill summerville
Model Number: mmv4205aas   Brand: Maytag   Age: 1 - 5 years
the replacement part i received for my microwave is the wrong temperature rating , the original thermostat rating is 150/0 . the part number sent was W10221406 ( thrnst-fix) the temp rating on that unit is 40/56 . the new part shuts down as soon as it reaches the low temp setting . the schematic diagram in the unit identifies the part as a MGT thermostat with KSD1 PR2 and the temp rating( 150/0) stamped on the face . When i match the part to your diagram , i get a thermostat with KSD1 with the temp rating of 40/56 stamped on the face . this part will not work . How do i identify the right part for this unit ?
serial # 11384268GT mfg date 05
Related Models
Maytag MMV4205AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAB14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAB17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAQ14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAQ17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAS14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAS17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAW15 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAW18 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5000ADA MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000ADB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000ADW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5165AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAB15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAS14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAS15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAW15 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAW16 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5186AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5201DB00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DS00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DW00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAQ17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BCB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW19 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5208WB0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WQ0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WS0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WW0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV6178AAB MICROWAVE - CONVECTION
Maytag MMV6178AAQ MICROWAVE - CONVECTION
Maytag MMV6178AAS MICROWAVE - CONVECTION
Maytag MMV6178AAW MICROWAVE - CONVECTION
Maytag MMV6180WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMW5527BAB WALLOVEN- S/C ELE
Maytag MMW5527BAW WALLOVEN- S/C ELE
Maytag MMW5527CAB WALLOVEN- S/C ELE
Maytag MMW5527CAW WALLOVEN- S/C ELE
Maytag MMW5530BAB WALLOVEN- S/C ELE
Maytag MMW5530BAW WALLOVEN- S/C ELE
Maytag MMW5530CAB WALLOVEN- S/C ELE
Maytag MMW5530CAW WALLOVEN- S/C ELE
Maytag MMW5530DAB WALLOVEN- S/C MWAVE ELE
  #2 (permalink)
Old 07-10-2009, 11:25 AM
Junior Member
Robi_Geek is on a distinguished road
Default
I'm looking for one as well. I've found several part numbers, now I'm trying to find them in the local area.
Quote:
serial # 11384268GT Manufacturer date 05
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bill K bkesler Washer Repair 1 01-13-2010 12:57 PM
Bill K bkesler Washer Repair 0 01-12-2010 07:52 AM
Bill w.potaris@verizon.net Dryer Repair 1 09-04-2009 11:39 AM
Bill wvwoodchuck48 Washer Repair 2 07-14-2009 01:57 AM
Bill Bill Mallard Dishwasher Repair 0 08-29-2008 05:32 AM
