Whirlpool Door
I used the microwave and it worked normally. Removed that food then placed more of the same in the unit and when I pressed start the word "door" appeared on the screen and it will not start. I have tried repeating it multiple times but not working. I have reset the power to it but still no help. I have someone scheduled to come out but it seems like it should be simple.
thanks, jay |
Hi Jay
Most likely the problem with your microwave is a bad door switch. The model number you posted does not look like a valid model number. Verify the model number and repost it, please. Gene. |
Whirlpool Gold Microwave Door Error
I found this question via a Google search and it is exactly the problem we are having. Unfortunately no answer. This is an in-wall over-microwave combination unit. The only numbers on the inside front of the unit are:
Tag on left side: 8538 791 54001 and under it XNR0568951 Tag on right side: UL FILE NO. E150072SP and under that FCC ID: KAW38AVM726 I'm sure this is likely a door latch sensor of some type, but where is it located and how difficult is it to replace. Thanks |
Quote:
Gene. |
Whirlpool microwave door error
Gene:
It is a microwave/oven in-the-wall combination. Whirlpool gold. The microwave door drops down (vs. opening on the side). Does that narrow is down? Thanks. |
If this is an oven/microwave combo then the name plate with the model number is on the Oven door frame.
Gene. |
Whirlpool combination oven/microwave built-in unit.
Model # GMC275PDR07 When trying to start microwave, the electronic screen says "DOOR" and unit will not work. Oven still works fine. I tried shutting down the power at the circuit breaker to see if it would re-set. No success. Any other ideas? Thanks! |
microwave problem fixed?
Hello JHOLT29,
I googled your posted problem regarding displaying "DOOR" error on your microwave. I recently got exactly same problem and wonder how you got it fixed? Can you please advise! Thank you! Daniel |
Whirlpool Microwave door error
Exact same issue and model! Any response on a fix?
| All times are GMT -7. The time now is 04:38 PM. |
