| » Underneath Lights have no power |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: jvm1631wb004 Brand: GE Age: 5 - 10 years
The problem happened when one of the bulbs broke and seemed to short out. Everything else is working just not the under lights, inside light is OK. I need help trouble shooting microwave lights not getting power. GE rep. mentioned probably need to replace the control panel? What part normally blows when the lights short out?
Mike Kreitzer
Remove all screws holding the bottom panel (were the lights are) and open it. Unplug the quick disconnect plug for the lights and using a simple meter check the power on the plug, pushing the light pad on the control panel. It should be 120V when the light switch is "on". If there is 120V then replace the light bulbs, check the sockets and wires. If there is no 120V (it could the power bun much less the 120V) then replace the control board. The part number for the new control board is AP3191409 - The break down diagram for the GE microwave Model JVM1631WB005 Good luck. Gene. |
| Display Modes | |
| DW has power and fills, but motor won't run | chuck67 | Dishwasher Repair | 5 | 07-29-2007 04:53 PM |
| Power Problems With Dryer | NESSDIST | Dryer Repair | 0 | 07-29-2007 01:36 PM |
| Duet Washing machine no lights | Derek | Washer Repair | 0 | 07-25-2007 05:49 AM |
| No Power to Machine | rebeccah | Washer Repair | 1 | 07-24-2007 01:24 PM |
