| » Maytag Gemini Dual Gas Oven Lower oven won't work |
Model Number: MGR6775ADW Brand: Maytag Age: 1 - 5 years
Year ago my upper oven stop working but broiler works. Replaced temp sensor oven still did not work. Approximately 9 months later my wife cleaned lower oven using self cleaning mode. After words lower oven failed and upper oven now works. However, the upper oven will not come on unless the lower oven is in bake mode (ie..... oven is in bake mode with temp at 115 but does not rise). The upper oven temp eventually rises to set temp. If this process is not use then the upper oven stays a 100 degrees and does not start. I believe the Electronic control is bad but still not sure. Any suggestions?
Very likely the control board has gone bad, but I also would check the igniters in both ovens.
Here are the breakdown diagrams and Replacement parts for MAYTAG MGR6775ADW | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Maytag Gemini Oven | ekuntz | Oven Repair (including Ranges and Cooktops) | 1 | 01-02-2010 07:20 AM |
| Maytag Gemini upper oven 15 deg low | Ragbag1 | Oven Repair (including Ranges and Cooktops) | 0 | 09-21-2009 09:18 AM |
| Maytag Gemini Dual Burner Fail | Jodice | Oven Repair (including Ranges and Cooktops) | 0 | 03-03-2009 09:57 AM |
| maytag dual oven, lower oven won't work | curt6 | Oven Repair (including Ranges and Cooktops) | 4 | 11-04-2008 12:26 PM |
| Oven Fan won't shut off and lower oven won't work | globalreleaf | Oven Repair (including Ranges and Cooktops) | 0 | 06-07-2008 01:27 PM |
