Discuss
Kenmore Elite Microwave dead
 in
Microwave Repair
I have a Kenmore Elite Microwave modle 565.61582010 It worked until I put food back in, shut door and set
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Kenmore Elite Microwave dead
  #1 (permalink)
Old 06-16-2009, 11:26 AM
Junior Member
Mayfair is on a distinguished road
Default Kenmore Elite Microwave dead
Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore Elite Microwave modle 565.61582010 It worked until I put food back in, shut door and set it to heat for a little longer. When I pushed the start button I heard a hum and then nothing - no light or clock. I removed microwave and plugged it into another circuit but was still totally dead. Is this a blown fuse caused by a door switch or something else? The door switch failed when it was under warranty and less than a year old. Also, two of the 4 screws in back look like torx heads but with a tip in the center of the torx hole thayt prevent insertion of the screwdriver. Obviously these are meant to prevent users from servicing units themselves. Any idea where to get such a screwdriver? Otherwise, I'll have to grab the screwheads and reove them some other way.
Ads By Google
  #2 (permalink)
Old 06-16-2009, 05:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You need a torx socket with a hole in the center. I believe you can find it in Sears. After you will remove the outer case from the microwave check the door switches, the capacitor and the fuse for continuity. Be careful and discharge the capacitor before any tests. Post the results.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dead! Kenmore Elite -Advantium 120 nmpinnyc Microwave Repair 71 05-15-2012 06:17 PM
Kenmore Elite dead after relamping partycrasher Microwave Repair 0 01-19-2010 10:41 AM
Kenmore Elite 665 Motor Dead redgal Dishwasher Repair 3 10-08-2009 05:37 AM
Kenmore Elite Washer Dead Trebbor Washer Repair 3 10-02-2009 06:30 AM
Dead Kenmore Elite Advantium Microwave beckon36 Microwave Repair 3 02-29-2008 03:13 PM
