Discuss
Jenn-Air - jmv8208bas - Microwave is running when not using it and door is closed
 in
Microwave Repair
I have a microwave that just recently started humming when the door is closed. I've unlugged it and plugged it
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Jenn-Air - jmv8208bas - Microwave is running when not using it and door is closed
  #1 (permalink)
Old 12-02-2011, 01:10 PM
Junior Member
spinca57 is on a distinguished road
Default Jenn-Air - jmv8208bas - Microwave is running when not using it and door is closed
Model Number: jmv8208bas   Brand: Jenn-Air   Age: 1 - 5 years
I have a microwave that just recently started humming when the door is closed. I've unlugged it and plugged it back in after a few hours and the problem no longer happened. Recently it started again where the humming only occured when the door is closed. So I tried putting a bowl of water in the microwave, and after a minute listening to the noise, I took it out and it was heated up.
I need some assistance on figuring out what part needs to be ordered.
i had a repair guy come out and claim this piece but he said it still wasn't 100% sure and I wasn't going to pay him $120 to attempt something he wasn't sure of.
WHIRLPOOL Asy Pcb Parts, part number: AP4264474
Need your help determining if this is worth trying?
Ads By Google
Related Models
Jenn-Air JMV8208BAS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BAW Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCQ Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCW Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAB Beaumark/washer
Jenn-Air JMV9169BAP Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAS Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAW Mwave - Mounted Over Range/wo
Jenn-Air JMW8130AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8130AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9130DAB Walloven - Std Mwave Ele
Jenn-Air JMW9130DAS Walloven - Std Mwave Ele
Jenn-Air JMW9130DAW Walloven - Std Mwave Ele
Jenn-Air JMW9330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAW Walloven - S/c Mwave Ele
General Electric JN30*01 Electric range
General Electric JN30*02 Electric range
General Electric JN319WIW Electric range
General Electric JN322*01 Electric range
General Electric JN322*02 Electric range
General Electric JN322*03 Electric range
General Electric JN322*J1 Electric range
General Electric JN322*J2 Electric range
General Electric JN322J3 Electric range
General Electric JN322S2 Gas range
General Electric JN322S3AD Range accessory
General Electric JN322S3WH Range accessory
General Electric JN322V1AD Range accessory
General Electric JN322V1WH Range accessory
General Electric JN327H1AA Electric range
General Electric JN327H1BB Electric range
General Electric JN327H1CC Electric range
General Electric JN327H1WW Electric range
General Electric JN327X1AD Range accessory
General Electric JN327X1CT Range accessory
General Electric JN327X1WH Range accessory
General Electric JN330*01 Electric range
General Electric JN330*02 Electric range
General Electric JN330*03 Electric range
General Electric JN334*01 Electric range
General Electric JN334*02 Electric range
General Electric JN334*03 Electric range
General Electric JN334*J1 Electric range
General Electric JN334*J2 Electric range
General Electric JN334J3 Electric range
General Electric JN334R1 Electric range
General Electric JN334S1 Gas range
General Electric JN335R1 Electric range
General Electric JN335S1AA Range accessory
General Electric JN335S1BB Range accessory
General Electric JN335S1WW Range accessory
General Electric JN361*01 Range accessory
General Electric JN361001 Electric range
General Electric JN630*01 Electric range
General Electric JN630*02 Electric range
General Electric JN630*03 Electric range
General Electric JN634*01 Electric range
General Electric JN634*02 Electric range
General Electric JN634*03 Electric range
General Electric JN634*J1 Electric range
General Electric JN634*J2 Electric range
General Electric JN634J3 Electric range
General Electric JN634R1 Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
jenn-air oven door won't stay closed christineb Oven Repair (including Ranges and Cooktops) 0 11-16-2011 07:55 AM
Jenn-Air Oven Door wont stay closed mmcharris Oven Repair (including Ranges and Cooktops) 0 06-13-2011 10:54 AM
Microwave Door Won't Latch closed Bob Hanke Microwave Repair 0 05-02-2011 04:16 PM
Microwave always running when door is closed Toolman102466 Microwave Repair 0 09-26-2010 07:46 AM
Jenn Air detergent door won't latch closed raddison Dishwasher Repair 0 11-23-2009 10:09 AM
