Discuss
Microwave no heat everything else works
 in
Microwave Repair
The microwave is working just fine but it will not heat the food. With Christmas just two days away how
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave no heat everything else works
  #1 (permalink)
Old 12-23-2007, 11:31 AM
loumtx loumtx is offline
Junior Member
loumtx is on a distinguished road
Default Microwave no heat everything else works
Model Number: RVM1335BC001   Brand: Hotpoint   Age: 5 - 10 years
The microwave is working just fine but it will not heat the food. With Christmas just two days away how can I fix it? I have looked at the diagrams and but I don't know where to access the unit to find the parts that need replaced. Cause of the problem and the way to access the area, greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-25-2007, 06:16 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
If the microwave does not make any unusual noises, then most likely the problem is a bad magnetron tube.
Set the microwave on the defrost for one minute and carefully listen to it. If you could hear when is switched from heat to non heat - no questions this is the faulty magnetron tube.
If the microwave is less then five years old then the part is still under the manufacturer warranty ("Use and care manual", page 40) and you have to call the GE.
- The part number for the magnetron tube is AP2025937
- Here are the break down diagrams for the Hotpoint microwave Model RVM1335BC001
Happy Holidays!
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven slow to heat up but broiler works drcain Oven Repair (including Ranges and Cooktops) 1 12-16-2007 03:16 PM
Microwave works but fan not running bnelson Microwave Repair 0 12-09-2007 08:56 AM
Frigidaire Gas Dryer works but No Heat, Why?? mvetri Dryer Repair 3 11-02-2007 04:46 PM
Microwave does not heat. 35mastr Microwave Repair 4 10-24-2007 07:51 PM
Whirlpool Oven won't heat stove works fine tnearman Oven Repair (including Ranges and Cooktops) 2 10-18-2007 10:13 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
