| » Microwave Repair |
Model Number: GH9176XMQ-O Brand: Whirlpool Age: 5 - 10 years
For the past few months microwave was intermittently making a humming noise during operation. Now the microwave stopped making the noise but is not warming food as it used to do. It takes longer periods of time for the food to warm. What is causing this problem?
Most likely the problem is a bad magnetron, but there is a small chance that the 1100W inverter (#21 on the diagram) is bad as well. I would replace the magnetron first.
- The magnetron Part number: AP3881382 - The 1100W inverter Part number: AP4364963 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GH9176XMQ0 Microwave Oven 1.8 Cu. Ft. | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
As soon as you will remove the microwave from the cabinet and remove the outer case, you'll see how simple it is.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com Last edited by Gene : 11-29-2011 at 04:15 PM. |
Yes. It has to be discharged. The instructions are attached to the reply.
__________________
Thank you for the discharging instructions. Do I also need to discharge the 1100 watt inverter board if I'm only replacing the magnetron? Do I discharge both terminals on the magnetron? From the instructions that you sent for discaharging the 1100 watt inverter board it looks like you use needle point pliers to discharge thru a resistor correct? If pliers are used; how do you recommend that I ground the pliers and to what? Can you send some instructions on how to test the magnetron with a voltage meter?
If the microwave has been unplugged for more than an hour it probably does need any discharging.
There is no any reliable instrumental test for the magnetron. That's why I mentioned two parts which could cause such problem. Gene.
__________________
| Display Modes | |
| GE microwave repair help | Tom in Crozet | Microwave Repair | 7 | 05-02-2011 08:39 AM |
| microwave repair | stillyrabbit | Microwave Repair | 0 | 12-22-2010 11:51 AM |
| Microwave Repair | makiel | Microwave Repair | 0 | 08-07-2010 08:22 PM |
| Microwave Repair | makiel | Microwave Repair | 0 | 08-07-2010 08:21 PM |
| Microwave Repair | lancegolf | Microwave Repair | 4 | 05-01-2009 01:41 PM |
