Discuss
Microwave Oven Door Alignment
 in
Microwave Repair
The microwave oven door on my Whirlpool GM8131XEB0 microwave/convection oven would not open. I was able to remove the outer
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Oven Door Alignment
  #1 (permalink)
Old 12-20-2007, 09:17 PM
Junior Member
doityourselfer_ed is on a distinguished road
Default Microwave Oven Door Alignment
Model Number: GM8131XEB0   Brand: Whirlpool   Age: 5 - 10 years
The microwave oven door on my Whirlpool GM8131XEB0 microwave/convection oven would not open. I was able to remove the outer housing and release the door by removing the upper "Latch board #3".
I quickly saw that there was a problem with the door latches and proceeded to remove the door from the oven. I did this by removing the hinges (#5) on the base plate and the oven cavity. Yes, I now know that this was not the best way to do this, and that it wasn't necessary to do this either.
After removing the "choke cover #5" from the door it was easy to identify that the bottom latch (#13) needed to be replaced. I have ordered those parts.
Two Questions:
1) In removing the choke cover #5, I managed to crack it in one spot. This part appears to be purely cosmetic and I believe that I should be able to reassemble this and not have to replace it, with the option of glueing it at the point where it cracked. Would you agree?
2) When I put the door back on I will have to align the door properly. I believe that a good test for this would be to close the door on a strip of paper, and then pull the paper out. I expect that I should feel a slight degree of resistence as I pull it out. I would then repeat this all the way around the door after making any adjustments. Would you agree with this procedure, or could you offer any advise on what I should do when I put the hinges and door back onto the oven again to obtain proper alignment.
Thank you!!
Ads By Google
Related Models
Whirlpool GM8131XEB1
Whirlpool GM8131XEQ0
Whirlpool GM8131XEQ1
Whirlpool GM8155XJB0
Whirlpool GM8155XJB1 Convection Microwave Oven
Whirlpool GM8155XJB2 Convection Microwave Oven
Whirlpool GM8155XJQ0
Whirlpool GM8155XJQ1 Convection Microwave Oven
Whirlpool GM8155XJQ2 Convection Microwave Oven
Whirlpool GM8155XJT0
Whirlpool GM8155XJT1 Convection Microwave Oven
Whirlpool GM8155XJT2 Convection Microwave Oven
Gaggenau GM915-710 UC/06 (FD 7710-7912)
Gaggenau GM915-710 UC/11 (FD 7912-8003)
Gaggenau GM915-710 UC/12 (FD 8003-)
Gaggenau GM926-710 UC/06 (FD 7710-7912)
Gaggenau GM926-710 UC/11 (FD 7912-8003)
Gaggenau GM926-710 UC/12 (FD 8003-)
Whirlpool GMA
Whirlpool GMC275PDB0
Whirlpool GMC275PDB07 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDB08 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDB1
Whirlpool GMC275PDB2
Whirlpool GMC275PDB3
Whirlpool GMC275PDB4
Whirlpool GMC275PDB5
Whirlpool GMC275PDB6
Whirlpool GMC275PDQ0
Whirlpool GMC275PDQ07 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDQ08 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDQ1
Whirlpool GMC275PDQ2
Whirlpool GMC275PDQ3
Whirlpool GMC275PDQ4
Whirlpool GMC275PDQ5
Whirlpool GMC275PDQ6
Whirlpool GMC275PDS07 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDS08 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDS1
Whirlpool GMC275PDS2
Whirlpool GMC275PDS3
Whirlpool GMC275PDS4
Whirlpool GMC275PDS5
Whirlpool GMC275PDS6
Whirlpool GMC275PDT07 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDT08 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDT6
Whirlpool GMC275PRB00 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PRB01 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PRQ00 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PRQ01 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PRS00 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PRS01 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PRT00 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PRT01 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDB0
Whirlpool GMC305PDB07 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDB08 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDB09 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDB1
Whirlpool GMC305PDB2
Whirlpool GMC305PDB3
Whirlpool GMC305PDB4
Whirlpool GMC305PDB5
Whirlpool GMC305PDB6
Whirlpool GMC305PDQ0
Whirlpool GMC305PDQ07 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDQ08 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDQ09 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDQ1
Whirlpool GMC305PDQ2
Whirlpool GMC305PDQ3
Whirlpool GMC305PDQ4
Whirlpool GMC305PDQ5
Whirlpool GMC305PDQ6
Whirlpool GMC305PDS07 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDS08 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDS09 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDS1
Whirlpool GMC305PDS2
Whirlpool GMC305PDS3
Whirlpool GMC305PDS4
Whirlpool GMC305PDS5
Whirlpool GMC305PDS6
Whirlpool GMC305PDT07 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDT08 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDT09 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PDT1
Whirlpool GMC305PDT2
Whirlpool GMC305PDT3
Whirlpool GMC305PDT4
Whirlpool GMC305PDT5
Whirlpool GMC305PDT6
Whirlpool GMC305PDZ0
Whirlpool GMC305PDZ1
Whirlpool GMC305PDZ2
Whirlpool GMC305PDZ3
Whirlpool GMC305PDZ4
Whirlpool GMC305PRB00 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRB01 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRQ00 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRQ01 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRS00 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRS01 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRS02 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRT00 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRT01 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRY01 30" Built - in Electric Combo Sensor/sc (gold Line)
General Electric GMR02AAMABB Refrigerator
General Electric GMR02AAMAWW Refrigerator
General Electric GMR02BANABB Refrigerator
General Electric GMR02BANAWW Refrigerator
General Electric GMR02BANBBB Refrigerator
General Electric GMR02BANBWW Refrigerator
General Electric GMR02BANCBB Refrigerator
General Electric GMR02BANCWW Refrigerator
General Electric GMR02BANDBB Refrigerator
General Electric GMR02BANDWW Refrigerator
  #2 (permalink)
Old 12-21-2007, 04:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
1) Probably you were right and this part is mostly cosmetic.
2) No, this is wrong. The most important is to have all door switches to engage properly when the door is closed.
While you will do it, remove the control panel to have access to the door switches. Replace the control panel after you done with the door.
- Here are the break down diagrams for the Whirlpool microwave Model GM8131XEB0
Good luck.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Oven door azgolfbum Microwave Repair 0 09-11-2009 12:51 PM
microwave oven door replacement mfbranham Microwave Repair 3 07-03-2009 02:44 PM
Installing Microwave oven door film donwrohde Microwave Repair 0 12-31-2008 01:16 PM
Refrigerator Door Alignment Julie Riggleman Refrigerator & Freezer Repair 1 10-06-2008 04:13 PM
