| » Whirlpool Microwave has no power |
Model Number: GH5184XPS-7 Brand: Whirlpool Age: 1 - 5 years
Hi there, this microwave is 2 years old. The past couple days it's been a bit finicky – meaning that it works when it wants to. I suspect that the door switch(s) are not working right. I just used it with the quick 1 minute button, then I opened the door to check the food - pow I lost power to the whole microwave. No sparks, burning smells or anything. Does anyone know what the problem could be? I'm very mechanical, Can I fix it myself?
Quote:
87Kustom, You're on the right track. Based on your post description, I would think the issue is in the door switch mounting assembly or one of the monitor switches. The microwave is "dead" because the in line fuse blew Part number: AP4308182 when the door switch "hung up". Heres some basic access information: REMOVING THE PRIMARY, SECONDARY, AND MONITOR INTERLOCK SWITCHES1. Unplug microwave oven or disconnect power. 2. Remove the control panel from the oven** 1. Unplug microwave oven or disconnect power. 2. Remove the microwave oven from its mounting location. 3. Remove front air vent by pulling forward at top of air vent and remove the air vent from the oven. 4. Remove the top screw from the control panel. Open the oven door, lift the panel, unhook the side latching tabs from the slots, and tilt the panel forward. ** To remove the primary, secondary or monitor interlock switch:a) Open the microwave oven door. b) Remove three screws from the front of the chassis to remove interlock switch assembly. from the oven. **c) Rotate the switch holder locking cams in a clockwise direction. This will unlock the switch assembly from the chassis. d) Remove the primary, secondary and monitor interlock switch assembly REASSEMBLY NOTE: Be sure to rotate the switch cam back to its original position after you reinstall the switch assembly on the oven chassis. ** You can now check all the switches and wiring, and the mounting bracket assembly and cams for distortion, loose or excessive flex in the assembly. Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Whirlpool no power to display will not turn on but has power to it? | jsross4 | Dishwasher Repair | 0 | 07-30-2011 08:28 PM |
| power surge whirlpool oven and microwave | jsmar | Oven Repair (including Ranges and Cooktops) | 1 | 05-12-2011 03:08 PM |
| Whirlpool Microwave Will Not Power Up... | FDAR | Microwave Repair | 1 | 09-20-2010 09:46 AM |
| No Power On My Whirlpool Microwave | waterskik | Microwave Repair | 0 | 04-29-2010 06:42 PM |
| whirlpool microwave power loss | alikatmack | Microwave Repair | 0 | 01-11-2010 06:23 PM |
