Discuss
Microwave Gasket or inside seal replace/repair
 in
Microwave Repair
The inside seal of on the microwave side wall has gotten damaged, there is a 5mm x 5mm hole in
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Gasket or inside seal replace/repair
  #1 (permalink)
Old 11-20-2011, 10:01 AM
Junior Member
Skibean is on a distinguished road
Default Microwave Gasket or inside seal replace/repair
Model Number: JMV1190BY 001   Brand: GE   Age: More than 10 years
The inside seal of on the microwave side wall has gotten damaged, there is a 5mm x 5mm hole in the seal on the top side. This is the seal that runs around the inside of the microwave between the side wall and the bottom. It got burned because the rack (which has been replaced) was missing part of it's protective coating and it burned the seal. My question is: what is the purpose of the seal? Is it just to make it easier to clean or does it hold in "damaging Rays"? The microwave works fine, I did a radiation test and there is no leaks. Can this seal be repaired or replaced? Thanks for your help
Ads By Google
Related Models
Jenn-Air JMV8000ADB Mwave - Mounted Under Cabinet
Jenn-Air JMV8000ADW Mwave - Mounted Under Cabinet
Jenn-Air JMV8000BAB Mwave - Mounted Under Cabinet
Jenn-Air JMV8000BAQ Mwave - Mounted Under Cabinet
Jenn-Air JMV8000BAS Mwave - Mounted Under Cabinet
Jenn-Air JMV8000BAW Mwave - Mounted Under Cabinet
Jenn-Air JMV8000BDB Mwave - Mounted Under Cabinet
Jenn-Air JMV8000BDQ Mwave - Mounted Under Cabinet
Jenn-Air JMV8000BDS Mwave - Mounted Under Cabinet
Jenn-Air JMV8000BDW Mwave - Mounted Under Cabinet
Jenn-Air JMV8100AAB Mwave - Mounted Under Cabinet
Maytag JMV8100AAB Mwave - Mounted Under Cabinet
Jenn-Air JMV8100AAQ Mwave - Mounted Under Cabinet
Maytag JMV8100AAQ Mwave - Mounted Under Cabinet
Jenn-Air JMV8100AAS Mwave - Mounted Under Cabinet
Maytag JMV8100AAS Mwave - Mounted Under Cabinet
Jenn-Air JMV8100AAW Mwave - Mounted Under Cabinet
Maytag JMV8100AAW Mwave - Mounted Under Cabinet
Jenn-Air JMV8166BAB Mwave - Mounted Over Range/wo
Jenn-Air JMV8166BAQ Mwave - Mounted Over Range/wo
Jenn-Air JMV8166BAS Mwave - Mounted Over Range/wo
Jenn-Air JMV8166BAW Mwave - Mounted Over Range/wo
Jenn-Air JMV8186AAB Mwave - Mounted Over Range/wo
Jenn-Air JMV8186AAS Mwave - Mounted Over Range/wo
Jenn-Air JMV8186AAW Mwave - Mounted Over Range/wo
Jenn-Air JMV8196AAB Mwave - Mounted Under Cabinet
Jenn-Air JMV8196AAQ Mwave - Mounted Under Cabinet
Jenn-Air JMV8196AAS Mwave - Mounted Under Cabinet
Jenn-Air JMV8196AAW Mwave - Mounted Under Cabinet
Jenn-Air JMV8196ACB Mwave - Mounted Under Cabinet
Jenn-Air JMV8196ACQ Mwave - Mounted Under Cabinet
Jenn-Air JMV8196ACS Mwave - Mounted Under Cabinet
Jenn-Air JMV8196ACW Mwave - Mounted Under Cabinet
Jenn-Air JMV8208AAB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208AAQ Mwave - Mounted Over Range/wo
Jenn-Air JMV8208AAS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208AAW Mwave - Mounted Over Range/wo
Jenn-Air JMV8208ACB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208ACS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208ACW Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BAB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BAS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BAW Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCQ Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCW Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAB Beaumark/washer
Jenn-Air JMV9169BAP Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAS Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAW Mwave - Mounted Over Range/wo
Jenn-Air JMW8130AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8130AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9130DAB Walloven - Std Mwave Ele
Jenn-Air JMW9130DAS Walloven - Std Mwave Ele
Jenn-Air JMW9130DAW Walloven - Std Mwave Ele
Jenn-Air JMW9330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAW Walloven - S/c Mwave Ele
General Electric JN30*01 Electric range
General Electric JN30*02 Electric range
General Electric JN319WIW Electric range
General Electric JN322*01 Electric range
General Electric JN322*02 Electric range
General Electric JN322*03 Electric range
General Electric JN322*J1 Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Inlet Gasket repair inside the Coupler Assembly Sizz Dishwasher Repair 0 09-17-2011 11:50 AM
Instruction To Replace Front Seal/gasket garystarh Washer Repair 1 06-03-2011 05:41 PM
replace gasket seal onrefrigderator door stephen daigle Refrigerator & Freezer Repair 0 08-03-2010 06:18 PM
New Door gasket won't seal garthpro Refrigerator & Freezer Repair 4 12-20-2007 03:34 PM
Microwave Door - Replace or repair? smc6429 Microwave Repair 1 11-14-2007 02:28 PM
