Discuss
microwave will not heat
 in
Microwave Repair
The primary winding on the H.V. Transformer is not showing any continuity when checked with voltmeter, Is this suppose
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » microwave will not heat
  #1 (permalink)
Old 12-18-2007, 06:10 PM
jgabbard jgabbard is offline
Junior Member
jgabbard is on a distinguished road
Default microwave will not heat
Model Number: gt4185skt2   Brand: Whirlpool   Age: 5 - 10 years
The primary winding on the H.V. Transformer is not showing any continuity when checked with voltmeter, Is this suppose to be like that and would that keep the microwave from heating?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-19-2007, 06:44 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
if you checked continuity through the primary winding, did you also check each leg of the primary winding to ground ? did you check the fuse also for continuity ?
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Does Not Heat. jpeterman12 Microwave Repair 2 03-22-2008 08:37 AM
microwave does not heat all else is ok geo Microwave Repair 20 12-19-2007 07:31 AM
Microwave does not heat Bob Shuler Microwave Repair 4 11-09-2007 12:31 PM
Microwave Won't Heat Ben Kiehl Microwave Repair 1 10-28-2007 02:51 PM
Microwave will not heat billr Microwave Repair 0 09-06-2007 05:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
