Discuss
Microwave Convection Oven
 in
Microwave Repair
The oven just stopped working. No power, no display on console. Changed one fuse (15 amp ceramic fuse). Power came
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Convection Oven
  #1 (permalink)
Old 12-18-2007, 05:00 PM
bc9ltjj bc9ltjj is offline
Junior Member
bc9ltjj is on a distinguished road
Default Microwave Convection Oven
Model Number: JVM290   Brand: GE   Age: 5 - 10 years
The oven just stopped working. No power, no display on console. Changed one fuse (15 amp ceramic fuse). Power came back on but as soon as I pushed button to heat, the fuse is blown again. What is the next step? Thank you for your help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-19-2007, 03:54 AM
MicrowaveDisplaycom MicrowaveDisplaycom is offline
Member
MicrowaveDisplaycom is on a distinguished road
Default
Quote:
If it blows as soon as you hit Start, that's almost always a shorted high-voltage capacitor.
You can buy parts and find helpful exploded views here: Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts
There is also a mini-manual hidden behind the control panel inside.
For critical microwave safety & disassembly tips, see all Microwave Display Repair Sharp Dacor GE General Electric & all Microwave Display Repair Sharp Dacor GE General Electric
  #3 (permalink)
Old 12-19-2007, 06:17 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
should use a multimeter to check HV Cap and also ohm out the mag tube as a short in the mag tub will do the same ...
__________________
regards
jim
  #4 (permalink)
Old 12-19-2007, 08:30 AM
Junior Member
Default
Thank you for your reply. I am a novice in electronics so I am not quite sure what I need to do to test. Do I need to remove the unit from the wall to do the testing or to replace the parts? MicrowaveDisplaycom seems quite sure the problem is from HV capacitor. If so, is this a good bet to replace it and see if it corrects the problem? What I mean, what is the chance of Mag tube being defective?
  #5 (permalink)
Old 01-03-2008, 10:45 AM
pcfucci pcfucci is offline
Junior Member
pcfucci is on a distinguished road
Default GE JVM1339BW002 Blows Fuse
I have a very similar problem. When I push the start button, the fuse blows as soon as it begins to draw high power, which is about 2 seconds after I push start. I have a multimeter, but not exaclty sure how to test the capacitor. Once I remove the two leads and touch the multimeter leads to the capacitor, what am I looking for to determine if it is bad? The microwave is about 10 yrs old.
Pete
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile convection/microwave ukusaok1 Microwave Repair 2 12-21-2007 01:29 PM
Convection Oven not heating well russ hibbeler Oven Repair (including Ranges and Cooktops) 3 12-11-2007 12:17 PM
Caloric Convection Oven caloricgold Oven Repair (including Ranges and Cooktops) 0 09-03-2007 07:45 PM
Convection Oven wedofood Oven Repair (including Ranges and Cooktops) 0 08-14-2007 01:01 PM
Convection oven not heating (microwave working fine) rm625 Microwave Repair 0 08-13-2007 04:41 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
